Rough idle
so I blew up my engine beyond repair so I bought a new one and rebuilt it. My truck is a 1995 3vze V6 4runner. The engine I got is a pre 91 3vze block. I got the new engine In and hooked everything up and set the ignition timing. It’s runbing really tough tho. On a cold start it runs and sounds fine, but as soon as it idles normally it runs really rough. I think it’s running rich because I can smell gas coming out the exhaust. It’s not a spark plug related anything because it’s all Been replaced(plugs, wires, cap, rotor). Any ideas? This engine got new injectors new and a new fuel pump. I also know the cams are in time and it’s not an issue like that. |
Have you put a timing light on it? Verified that all wires are in the correct firing sequence? Checked for vacuum leaks with a can of carb cleaner or starting fluid? What codes is it throwing? If its running that bad it will probably trip a code if left to run long enough. 3.0 are not my wheelhouse by any means. Just some basic trouble shooting for the symptoms you described.
Got it fixed. It ended up being the EGR vacuum line got switched so it was stuck open. |
