Sponsored by: CARiD
Replacing power steering pump
Old Nov 20, 2007 | 08:38 AM
  #41
b.miller123's Avatar
Originally Posted by slowheelin
oops missed that. I think I can figure it out with that info there.
I wouldn't know where to begin working on a 56ft jet. I've seen the inside of an engine for a Cessna Citation X before and DAMN! There's a lot goin' on there.
Well, thats what the military can do for you! I worked on EA-6B Prowlers for about five years, and it takes a few years to really know what's going on. Anybody can do metal-work and remove and replace components (most of what my job consisted of) but getting everything to work right, and being the guy who signs off on repairs and says "yes, it's good, now put 4 naval officers in it and go fly 400 miles an hour" that's a whole nother level that takes time to get to
PS, not trying to get you or anyone else to join the military, I did, I had fun, I got out and went back to college
Old Mar 8, 2008 | 11:13 AM
  #42
jason191918's Avatar
Just thought I would add the easiest way to remove the pulley.
Use a pickle fork (ball joint separator).
Worked quickly and easily.
Old Mar 8, 2008 | 08:38 PM
  #43
Chalk up another Power Steering Pump Replacement thanks in part to YT. I am 99% sure that I hooked up the vacuum lines correctly, but when at full lock the idle dips a lil bit (approx 100 RPM)...Is this normal or should it be going up by this much?
Old Mar 9, 2008 | 07:15 AM
  #44
Brenjen's Avatar
If it goes up instead of bogging down, you have it on correctly. I checked on that air valve & that thing is outrageously expensive even though it isn't a dealer only part. I just plugged mine off after breaking one of the nipples & I have had no ill affects after my PS pump rebuild (which was simple btw) I'd call the entire job of removal, rebuild & reinstall a 3 on a scale of 1-10 & that's only because I have relatively big hands.
Old Mar 9, 2008 | 07:33 AM
  #45
dirtoyboy's Avatar
Originally Posted by MudHippy
I've been running mine with PS fluid since I rebuilt it about 6 months ago. No problems yet. I don't even use the synthetic either. I know there's another guy on here that does too. He hasn't had any trouble running his with that valvoline synthetic that you bought. Give it to me if you don't want it. j/k
My advice is don't mix, use one or the other.
Oh, my observations are also a quieter running pump with the PS fluid. Not a whole lot, just a little maybe. It used to groan at me louder when it strained with the ATF.
You should really use ATF in your power steering system. There is a reason why your service manual specifies ATF. Steering fluid will destroy your seals. I have seen a good box start leaking in under a week after switching from ATF to steering fluid.
voiddweller
19
May 2, 2016 09:10 PM
1badyota350
Jun 28, 2015 06:50 AM
paxanders
Jun 21, 2015 06:29 AM
jx94148
Aug 24, 2002 09:45 PM
