Sponsored by: CARiD
Old Apr 13, 2016, 08:38 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Electrical Guides
Print Wikipost
Replacing negative battery cable
Old Jan 15, 2010 | 01:06 PM
kev7706's Avatar
I need to replace the negative battery cable on my 4Runner. I followed the cable into the loom, but I need to find out where it bolts to on the other end. I want to avoid cutting into the loom and just run a new negative cable since the positive cable is still in good shape. Can someone direct me to the ground location of the negative cable? Thanks
Old Jan 15, 2010 | 01:11 PM
Elton's Avatar
i just ran 3 new 4ga ground wires on my truck one to the fender the frame and the alt bracket
Old Jan 15, 2010 | 04:46 PM
myyota's Avatar
Do a search for the big 3 mod, that will help you alot.
Old Jan 16, 2010 | 04:08 PM
wyoming9's Avatar
Red face
i make my own battery cables out of #1 welding cable I run one to the inner fender another to the steel engine block .
If you have a cranky starter I have also run a ground cable to the upper starter bolt but that can be a pain
This along with the replacement of the wire off the B terminal of the Alternator cures a bunch of charging and starting issues.
Old Jan 16, 2010 | 04:58 PM
kev7706's Avatar
Thanks for the help everyone. So I'm assuming the stock setup includes only 2 grounds - a ground to the inner fender and to the engine block?
Old Jan 16, 2010 | 07:00 PM
myyota's Avatar
The stock set up has two grounds off the battery, the inner fender and to the engine block, but it doesn`t hurt to add a few more and use a heavier gauge wire than stock.
kazuya2416
Apr 5, 2024 02:17 AM
shar
Jul 9, 2015 12:38 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
skoti89
Jul 8, 2015 12:05 AM
colinmil
Jul 6, 2015 04:03 PM
