Last edit by: IB Advertising
Browse all: Toyota 4Runner Electrical Guides
- Toyota 4Runner 1996-2002: How to Replace Battery
Step by step instructions for do-it-yourself repairs.
Replacing negative battery cable
I need to replace the negative battery cable on my 4Runner. I followed the cable into the loom, but I need to find out where it bolts to on the other end. I want to avoid cutting into the loom and just run a new negative cable since the positive cable is still in good shape. Can someone direct me to the ground location of the negative cable? Thanks
i make my own battery cables out of #1 welding cable I run one to the inner fender another to the steel engine block .
If you have a cranky starter I have also run a ground cable to the upper starter bolt but that can be a pain
This along with the replacement of the wire off the B terminal of the Alternator cures a bunch of charging and starting issues.
The stock set up has two grounds off the battery, the inner fender and to the engine block, but it doesn`t hurt to add a few more and use a heavier gauge wire than stock.
skoti89
Jul 8, 2015 12:05 AM
