Sponsored by: CARiD
replace rod bearings without removing the engine?
Old Aug 17, 2011 | 06:23 AM
fooloflife's Avatar
Question replace rod bearings without removing the engine?
My 95 4runner 3VZE has 210k miles and started knocking so I've been taking the light rail for and lurking on this forum for a year or so until I had the time and money to try to fix it. YotaTech is awesome, btw, and from what I can tell from different posts on here I think it's a rod bearing. I'm going to get her up and running, check the oil for metal and take the oil pan off to verify sometime in the next couple weeks.
Anyway, my question is: if it is a rod bearing, can it be fixed without removing the engine? I don't have a cherry picker or an engine stand so I'd like to jack her up and fix it with the pan off if possible. Has anyone done this before that could offer tips?
Thanks!
Old Aug 17, 2011 | 06:39 AM
blake.nemitz's Avatar
a rod bearing yes its pretty easy, however if its bad enough to knock it is probable the the crank is damaged and will need to be machined
voiddweller
19
May 2, 2016 09:10 PM
DacodaYota
Sep 2, 2015 02:13 PM
Iceman4193
Jun 28, 2015 10:30 AM
jjrbus
Jun 27, 2015 12:56 PM
TheManOutside
Jun 18, 2015 03:32 PM
