Sponsored by: CARiD
Repeatedly failing mechanical fuel pump
Old Oct 24, 2017 | 05:08 AM
Josport48's Avatar
Hello everyone,
I recently bought an 87 Toyota pickup in decent shape but the fuel pump keeps failing, I am thinking the tank could have sediments in it or something along those lines but I thought I would ask other opinions. Other than that would there be any other things to check or reasons why it would be killing one fuel pump after another, I have put 2 new ones on it now.
Thanks in advance!
Old Oct 24, 2017 | 05:27 AM
millball's Avatar
Seems I recall that there is supposed to be a shim that spaces the pump out from the head, effectively shortening the pumps stroke.
Does your engine have this spacer installed between the pump and the head??
Like this:::
https://images.search.yahoo.com/yhs/...f&action=click
Old Oct 24, 2017 | 06:55 AM
Josport48's Avatar
That was the problem, no shim in between the pump and the block. Thank you so much millball!!!
Old Nov 2, 2017 | 02:26 PM
Josport48's Avatar
Well another fuel pump went bad but this time it is leaking out of the weep hole in the bottom of the pump, just pump defect of something else???
Old Nov 2, 2017 | 02:56 PM
old87yota's Avatar
What brand of fuel pump are you using?
Did you get a new fuel pump AFTER you installed the spacer?
Old Nov 2, 2017 | 03:35 PM
Josport48's Avatar
Car quest.
Yes brand and new pump after spacer
Old Nov 2, 2017 | 11:55 PM
wyoming9's Avatar
Red face
Poor quality on the last pump .
Maybe you have a fuel pump curse did you make anyone mad??
Old Nov 3, 2017 | 06:29 AM
Josport48's Avatar
Hahaha I must have. I think the truck sat for a while before I bought it and I’m just catching all the little thinks that have went out over time. I’m going to clean the tank and put in another fuel filter to see if that helps
Old Nov 12, 2017 | 05:00 AM
Josport48's Avatar
Yet another pump went bad. Leaking out of the weep hole again. Not sure what to do anymore
Old Nov 12, 2017 | 05:50 AM
millball's Avatar
Has any one of these pumps been a genuine Toyota spare part??
What were the countries of origin??
Old Nov 12, 2017 | 06:36 AM
Josport48's Avatar
They are aftermarket, car quest made in the USA. That’s just the brand of fuel pump the part stores near me carry. I’m open to any ideas, I’ve been trying to look up different brands that might be better.
Old Nov 12, 2017 | 09:49 AM
L5wolvesf's Avatar
Just a thought. Have you looked at the fuel pump drive eccentric?
also
How thick is the spacer you are using?
Old Nov 12, 2017 | 10:03 AM
dropzone's Avatar
Fossilized
also
from what I remember there are two different thickness spacers, been awhile since I my 84 with a 22R but I had similar issue eating pumps, i had the smaller spacer.
Old Nov 12, 2017 | 04:18 PM
Josport48's Avatar
I have not checked the eccentric. I will check that next then and I am using a spacer that looks to be about an 1/8 inch thick.
Old Nov 14, 2017 | 09:09 AM
L5wolvesf's Avatar
I just measured the spacer on mine 1/4 inch thick, black plastic-like material.
Old Nov 14, 2017 | 09:23 AM
Josport48's Avatar
Thank you! I just got a call back from the local toyota dealer and they said the same. I will be replacing my spacer. Fingers crossed. Thank you all for all the help!!!
Old Apr 20, 2018 | 03:57 PM
gixxsta04's Avatar
Can you put an electric fuel pump on these? Are mechanical pump block off plates available?
Old Apr 20, 2018 | 05:55 PM
dropzone's Avatar
Fossilized
yes, make sure you get one with the correct fuel pressure or add a regulator.
LC engineering would have the block off plates
