Sponsored by: CARiD
Question About Lift/Tires 06 4Runner
Old Aug 31, 2006 | 03:26 PM
Blackhawk's Avatar
I'm sure that this is a stupid question, but it's my first post, so it's to be expected. I have a 06 4Runner SR5. I want to lift it about 2.5-3 inches.
Would this do the actually lifting of my truck?
http://www.burtmanindustries.com/zoo..._03_up_liftkit
And, another dumb question. Is there a size difference between P265 tires, and LT 265 tires. When I put the lift on it, I want 32 inch tires. Would that be LT265/75R/16 ? For these wheels.
http://www.wheelersoffroad.com/4runnerwheels.htm
Thanks guys.
Old Aug 31, 2006 | 03:30 PM
wjwerdna's Avatar
yup, its a stupid question
Old Aug 31, 2006 | 03:31 PM
wjwerdna's Avatar
but.... yes, those are part of what lifts your vehicle
search "spacer lift" or "front spacers" or "spacers" or something for more info
in theory those are 31.65 inches....
Tire Size Calculator
read this
Sidewall Info
for info on tire ratings and meaings, and this for more info
Tire Types
Welcome to yotatech... remember to search, i feel that most of the questions you are going to post at first will all have been covered numerous times before... spend some time browsing around
and if you started by placing this thread in the newbie section vs a mod putting it there, props to you !!!
Old Aug 31, 2006 | 03:33 PM
Blackhawk's Avatar
ok sorry. now can someone answer my second question please?
And what does a snorkle do?
Old Aug 31, 2006 | 03:36 PM
91_4x4runner's Avatar
LT = Light Truck.
A snorkel re-routes your air intake from its stock location in the engine bay to a higher location. A snorkel is a good preventative to hydro-locking your engine when you go through a water crossing.
Old Aug 31, 2006 | 03:37 PM
Blackhawk's Avatar
So a LT265 would be bigger than a P265?
Old Aug 31, 2006 | 03:38 PM
Not necessarily. I think it's actually a higher load rating.
Old Aug 31, 2006 | 03:39 PM
Blackhawk's Avatar
well, then what size LT tires would I buy for say....33" tires with 16" x 8" wheels.
Old Aug 31, 2006 | 03:41 PM
wjwerdna's Avatar
285-75-16 are roughly 33.... (updated one of my posts with really cool tire links and explanations to discount tire website )
Old Aug 31, 2006 | 03:43 PM
Blackhawk's Avatar
Ok thanks man.
Which one of these lift kits would you guys recommend? Price doesnt matter.
http://www.burtmanindustries.com/zo...n_03_up_liftkit
OR
http://www.wheelersoffroad.com/03uprevtek4runner.htm
And those both are the only things I would need to buy to lift it right?
Old Aug 31, 2006 | 03:45 PM
wjwerdna's Avatar
if price didnt matter i would not go with a spacer lift.... (gimme a couple seconds, im doing your research for you )
Old Aug 31, 2006 | 03:55 PM
wjwerdna's Avatar
ok, so it looks like with your year 4runner, and the xreas system, a spacer lift is better (to avoid xreas problems) vs a longer coil lift.... with a 3rd gen 4runner (you have a 4th gen) its recommended that you also buy a diff drop kit (search if you wanna know) but on the 4th gens 'I' dont know...
the revtek pics show the extended studs and everything that you would seem to need
Old Aug 31, 2006 | 04:00 PM
Net4N6's Avatar
He has an SR5. It doesn't come with XREAS.
I ordered cornfed spacer kit. I heard good feed back from members here. I will have it install next week. PM me if you have other questions.
Old Aug 31, 2006 | 04:08 PM
wjwerdna's Avatar
ahhh.... my bad, i thought that they all had xreas and it was just the air-susp leveling system that was optional....
Old Aug 31, 2006 | 04:26 PM
Good Times's Avatar
spacer lifts are an entry level lift kit solution. Over time they will make your ride harsh. Read up on spacer lift to get real world experiences on those that have/had them. It's the cheapest lift solution available to the market that'll give you instant lift. Long term, you'll want to remove the spacers and look into a more traditional coil/shock solution such as OME. OME lift will give you the same lift (height wise compared to any spacer lift that are 2-3") but retain the stock feel. Please do a search on "OME" and "Spacer Lift" for more details on these solutions. Don't forget to read up on the 4th gen 4runner / 05 + taco section for other details on some other lift solutions which are more $$. you can get 265/75/16 with no lift and not rub if you want to upsize now or you can wait until you get your lift. if you want to go big you can even go 285.75 but do remember that rubbing will occur. 275's may be available but please consult your local tire depo for more info on availabilty.
diff drop. don't need em for the 4th gen 4runner so don't bother searching for that.
Good luck and welcome to yotatech
Old Aug 31, 2006 | 04:35 PM
Blackhawk's Avatar
So I would be better off, longterm, installing the Revtek?
And this 3" lift would allow LT285/75R/16 tires no problem? No rubbing?
Old Aug 31, 2006 | 05:35 PM
Blackhawk's Avatar
Yet another lift question.
If I were to install a 3" lift on my 06 SR5 4Runner, would my Electronic Stability Control be compramised?
this is the lift.
Thanks.
Old Aug 31, 2006 | 08:02 PM
Good Times's Avatar
trying to fit 28t's will mean rubbing - no way around it. Even if you get All Terrains you're still going to rub. It's the nature of getting such a large tire in the small wheelwell. Do a search on the exact specification on what works and does not work as this forum has lots of information documented exactly on what you are searching for.
fyi revtek's are still spacers...
Old Aug 31, 2006 | 08:19 PM
Good Times's Avatar
thread merged.
Old Aug 31, 2006 | 08:27 PM
Blackhawk's Avatar
would 275LT/75R/16 size tires rub at all?
and what inexpensive 3" lift would you recomend?
