Sponsored by: CARiD
Power steering Pulley 1989 V6 4x4 Pickup
Old Dec 6, 2011 | 10:01 AM
1stoy's Avatar
I know it can't be placed backwards...I was just wondering about the key. I have a pulley holder to stop the pulley from turning as I re-remove the nut. Then I should be able to see if the key is missing, right??? And then can I just purchase a new key and install it???
Originally Posted by DeathCougar
Its not possible to put the pulley on backwards
Old Dec 6, 2011 | 10:18 AM
James Woods's Avatar
So what it sounds like is either you sheared off the key or it is missing all together so when you turn the wheel, the pulley slips on the shaft and grabs everyonce in a while so that is why the wheel jerks. If you never took the pulley off then you sheared the key and there is to much damage to just replace the key most likely, you will have to tuff it out without PS until you have money for a new pump.
Old Dec 6, 2011 | 11:13 AM
bassbro1's Avatar
Check junkyards for keys, pick up full pump from junkyard for parts.
Old Dec 6, 2011 | 03:02 PM
1stoy's Avatar
Damn....ok goog looking out. Imma try and work on it tonight and see if i did shear the key.
Old Dec 6, 2011 | 09:43 PM
  #25
wyoming9's Avatar
Wink
I have never seen a woodruff key shear off I guess it is possible I have had pump bearings seize but most often the belt just slips to it burns off.
If that is the case and the pump is seized it is kind of a moot point .
Old Dec 10, 2011 | 04:25 PM
  #26
1stoy's Avatar
So I fixed it(for now). I just placed two washers against the pulley and tightened the nut. Works like a champ now. thank u thank u thank u, for all the advice. i learned a lil' more about my truck.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
scott90
Oct 4, 2015 09:21 AM
dbollier123
Sep 29, 2015 05:23 PM
