Sponsored by: CARiD
Please Help!86 runner :bang: :bang:
Old Dec 29, 2008 | 01:21 PM
ed4stoy99's Avatar
OK ,I have a 86 runner with a 92 engine.22RE ,I had to replace the wire harness under the dash and the one going from the ECU out to engine. The one that goes to fuel injectors .Got it all back together ,starts right up but wont idol .If I give it gas it will stay running ,till I let off the gas.Also engine light goes on and off.I checked all vacuum lines,they are all good and plugged back in .Any ideas.
Old Jan 7, 2009 | 11:11 AM
ed4stoy99's Avatar
Old Jan 7, 2009 | 12:31 PM
22mr2's Avatar
did your swap include the diagnostic connector? You might want to see what codes its trying to spit out. You could try to up the idle screw a bit to see if you can keep it running and get a better idea of whats up. Double check all your connections and make sure you did not overlook anything. Timing off?
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
cyclist231
Jul 7, 2015 12:56 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
