Sponsored by: CARiD
OME Springs Stock Shocks
Old Apr 30, 2008 | 01:17 PM
DesertDuneLimi's Avatar
Even though I couldn't find an answer after extensive searching on YT, I still decided to post this in the newbie section, so I wouldn't get ripped a new one by all the search nazis.
I read somewhere (not on this forum) that you cannot use OME springs with stock shocks/struts. Is this true? I don't have the money to upgrade my shocks right now, but still want some lift...96 ltd.
Old Apr 30, 2008 | 01:21 PM
gilby4runner's Avatar
how much lift are you looking for? The 99 coils would give you a little boost.
Old Apr 30, 2008 | 01:22 PM
Mic09dcsm's Avatar
They say that because the stock shocks don't have the range for the lift, they will bottom out because they literally have no more slack or room to compress/decompress, which negates the effectiveness of the shocks.
Old Apr 30, 2008 | 01:35 PM
Not looking for too much, but more than the 99 springs. I am actually leaning towards the pp 1" springs.
Old Apr 30, 2008 | 01:44 PM
hurley842002's Avatar
Most OME springs have very minimal lift, depending on application. OME builds all of its components to work together to give you an optimal ride. From what I understand OME shocks are valved to work specificaly with OME springs, that shouldn't mean you CAN'T use other shocks, they just won't give you the ride that using all OME products will.
Old Apr 30, 2008 | 01:45 PM
the 99 coils would give you the same amount i believe.. might be cheaper. Do you have a link to the PP springs?
Old Apr 30, 2008 | 02:26 PM
flyfishexpert's Avatar
LINK.
Old Apr 30, 2008 | 02:53 PM
I've been reading that most people who put these on 4runners other than 99 are getting anywhere from 1.5-2" lift.
I've also been considering the OME 906 in the rear paired with either the tundra springs or the OME 881's in the front.
Old Apr 30, 2008 | 03:00 PM
Psalm 112's Avatar
906's are rated at 2 inches. you should be ok with stock shocks.
Old Apr 30, 2008 | 03:07 PM
So, Psalm...where in the burque are you.
Old Apr 30, 2008 | 03:15 PM
Psalm 112's Avatar
how do the homeboys say it..."WEST-SIDE"
Last edited by Psalm 112; Apr 30, 2008 at 03:36 PM. Reason: the regular font does not give WEST SIDE justice
Old Apr 30, 2008 | 03:55 PM
I thinks it's actually west-si-EED
Flying91
45
Apr 11, 2024 04:39 PM
nvdesertrunner
May 11, 2020 08:18 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
bobpat
Aug 1, 2015 09:25 PM
