The OFFICIAL IFS "What size tire will fit" thread
#62
Im not good at metric sizes. But i had a 2.5 lift on my 03 taco and ran 29x10.50 super swamper sx on stock rims . no problem. then i added a 3" body and ran 33x12.50x15 tsl radials. i used procomp rims with a crazy offset. no rubbing. then i took the 2.5 suspinson lift off and put a fabtech 6" suspinson plus the 3" body i already had and cleared 37x14x15 IROKS with no rubbing...... hope this all helps u with ur taco
#63
255/85/16's rub in the rear of taco's when using ome leaves, because they bring the axle foward a bit. this can be fixed by buying relocation plates from various places, got mine from sky
255's fit in the front fine with tundra springs.
#65
Will these tires work???
Hi, sorry if this answer is on here but I did a search and couldn't find anything. Does anyone know if 265/75/r16 tires will fit okay on an '89 4x4 Pickup without any issues besides the speedometer? The tires are Goodyear Wrangler "territory" Thanks
#71
Ok I see that some of the more experienced yota owners get tired of hearing this question, but here it goes. I have 07 4Runner with stock 265/65R/17 and I really like the stock rims however I want a more aggressive tread so. What do I need to do to get a similar look like creighton43? I really like that by the way. I hope this does aggravate yall too much but this is "The OFFICIAL What size tire will fit thread" and all. Thanks a head of time for the info.
#72
I've got 15x8 wheels with +6 offset. Is this offset going to help or hurt with either 31/10.5/15's or 32/11.5/15's on a stock '93 with running boards. I bought the wider wheel in hopes that it would be good but am unsure what the offset does for me.
#73
so i have a 2000 4runner SR5 4x4 and I also have but and getting rid of a 1990 chevy k1500 with the stock aluminum 16in rims wrapped in 265/75 Kumho Road Venture AT's.... and i checked the Pro Comp Wheel conversion chart for bolt patterns and am supper suprised but it says that the 4runner and the chevy have the same bolt pattern. I am stoked because the Kumhos are brand new and why not just throw my Kumhos and rims on the the 4runner... is it possible? if not why? the 4runner has 22575r15... help me! 3 in suspension lift is soon to come
#76
I have been searching for an answer to this... I have a 91' hilux surf with 3" body lift and 3" suspension and just put 35x12.50R15 KM2's on and want to know if its to big a tire for the stock gearing and IFS ?, I think it would have looked dumb with 33"s. I bought it with the lift and 35x12.50R15 MTR's and they rubbed the back of the wheel well at the bottom if i hit a bump at full steer lock just a bit and only till they wore out a bit, but looked good.
#77
don't every do any kind of modification like suspension or tires because it "looks stupid" remember you gotta build the truck to work, not look cool. its like seeing ricer's on the street with loud exhaust and chrome but no engine to back up the looks... that is STUPID
#78
im not really hard on my truck though, and the added clearance is nice for in the mud in deep ruts since most people have made ruts with 40"+ tires up around here. I was just wondering if the tires will wreck it man.
#79
i have a 1990 pickup 3vze. I want to put some 31x10.5 on 15x8" rims with 3.75 backspacing. How far will the tires be out of the fender? i like the look. i assume i will have rub, would a 2 in. body lift eliminate any potential rub?
#80
2008 Sport Edition 4Runner Stock Height.
Currently running stock 265/65/17's
Planning on purchasing BFG All-Terrain T/A's in 265/70/17 (same size as FJ Cruiser). All research points to no rub issues - barring anyone chiming in, will place an order in the next 30 days.
