Sponsored by: CARiD
newbs plan of attack for a clutch job
Old Apr 30, 2008 | 02:05 PM
bigt's Avatar
ok so i need to do a clutch im my trail rig.. i have a tranny jack
now right by the cross member connected to the tranfser case there is this support with a rubber block on it.... can i use my floor jack to support tranny under this while i remove cross member so i can remove front drive shaft so i can put my tranny jack under it??
also my sockets wont fit on the drive shafts .. and i cant get any torque on a small 12mm wrench..
im planning out my attack for friday afternoon ..while tranny is out im going to install my welded rear and then drop the truck anbd change a cv.. pb blastering mon-fri!!!!!!
yotatech rocks and thanks in advance
i also have 2 feet in extension and a clutch alignment tool, pilot bearing and throw out bearing.. im not doing the seals because if it aint broke dont fix it and its just a trail rig!
Old Apr 30, 2008 | 11:40 PM
Bwilson52's Avatar
when i changed the clutch in my 84 nissan 720 i didnt even take it all the way out just slided it back outta the way enough to pull the clutch out.i used some persuaders and a few floor jacks
Old May 1, 2008 | 04:47 AM
bigt's Avatar
is this little part off the transfer case made for a jack to support tranny??? both my runners have it but it doesnt say anything about it in my man ual
Old May 1, 2008 | 05:26 AM
zlathim's Avatar
[/COLOR]
now right by the cross member connected to the tranfser case there is this support with a rubber block on it.... can i use my floor jack to support tranny under this while i remove cross member so i can remove front drive shaft so i can put my tranny jack under it??I'm not completely sure what you are asking, but I'll take a stab at it. I think you want to support the trans-t/c so you can remove the crossmember, in order to make it easier to remove front ds. Yes, you can do this, but the tricky part is switching jacks when you need to. It usually requires using something smaller like a bottle jack instead of a floor jack. You should be able to figure something out, but remember to be safe.
also my sockets wont fit on the drive shafts .. and i cant get any torque on a small 12mm wrench..get some that fit
im planning out my attack for friday afternoon ..while tranny is out im going to install my welded rear and then drop the truck anbd change a cv.. pb blastering mon-fri!!!!!!You have your work cut out for you. Good idea using the PB on all the rusty stuff.
i also have 2 feet in extension and a clutch alignment tool, pilot bearing and throw out bearing.. im not doing the seals because if it aint broke dont fix it and its just a trail rig! sounds like you have the extentions covered, how are you planning to remove the old pilot bushing?
Old May 1, 2008 | 08:50 AM
dirtoyboy's Avatar
Do you have grab handles on the inside? If so, all you need is a regualr floor jack and ratchet strap to safely do it yourself
Old May 1, 2008 | 08:53 AM
dirtoyboy's Avatar
Old May 1, 2008 | 03:02 PM
bigt's Avatar
i have a floor jack to put under the tcase.. THEN once i get the cross member off im going to use my other floor jack with TRANNY ADAPTER to pick up the tranny.. i have a bottle jack under my engine and the truck is up on 4 jack stands!
what i means about the sockets is my drive shaft the way it connects i dont think i could get any sockets on it.. almost like you need to use a wrench from the side for clearence... if that makes any sense...
the pilot bushing i was going to try the grease trick i have also read about using wax but i dont know if they mean to melt wax in there or just shove some parafin wax in there..
thanks guys.. and dirtboy toy im amazed at your idea of the o ish handles!
Old May 2, 2008 | 10:34 AM
bigt's Avatar
rained out today..
say myclutch slave cyclinder looks old the mast look new... should i order a new slave??
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
Sr5crawler
Jul 31, 2015 12:32 PM
defrag4
Jul 31, 2015 10:50 AM
colasurdo
Jul 16, 2015 11:32 AM
