Sponsored by: CARiD
newbie from north ga. here!
Old May 19, 2014 | 06:35 PM
Wood Racing's Avatar
Hey there my name is Mark. I bought my first toyota truck a few montjs ago. Its a 1993 ex cab, 3.0, 5spd. I got it for $800 due to it needing head gaskets and a slave cylinder. Just finished tje repair. While I had it apart I had the heads cleaned and resurfaced, replaced all top end gaskets, did new timing belt, idler pulleys, water pump, and did full tune up. I have a few bugs to work out but its running. I have a engine code #31, idle is revving between 1000-1500rpm (extremely annoying) and it boggs under full throttle.it runs fairly well if I drive it easy. Any suggestions would be appreciated. I also have to replace the muffler any suggestions for a good muffler for a 3.0 would be good to.
Old May 21, 2014 | 04:15 AM
Well it left me on the side of the road yesterday. No fire to the coil. I went and got my trailer and inlaws truck and towed it to the shop. And when I pulled it off the trailer it fired rite up.
Old May 21, 2014 | 05:25 AM
Rowdydudeman's Avatar
sounds like you've got some grounding issues...
Welcome to YT!
Old May 21, 2014 | 12:52 PM
Thanks for the welcome. It just so happens that there is a ground I didnt hook up......its still bogging under throttle I think I have one if the cams a tooth out.
Old May 22, 2014 | 06:29 AM
reallifedog's Avatar
Welcome fellow Georgian!
Old May 22, 2014 | 11:31 AM
Im still having the same issue. It runs along fine then all of a sudden no fire???
Old May 22, 2014 | 11:34 AM
nacheswheelin's Avatar
Is the distributor possibly cracked? I had spark sometimes then no spark, and that was my solution? Also id search for a ground again.
Old May 22, 2014 | 06:04 PM
Im pretty sure I got all the grounds. Im pretty sure its either the distributer or igniter pack. Igniter is $200 so I wanted to make sure before I spent the cash. Im gonna check tje distributer for cracks tomorrow.autozone says theu can check the igniter pack so I plan on doing that before I buy one.
Old May 22, 2014 | 09:43 PM
rokblok's Avatar
I have an '88 4Runner with a blown 3.0. If the igniter or distributor will work on yours, you're more than welcome to them. I live in Tennessee now, but I will be going to ATL next week for work, if you can meet on 75 somewhere.
Let me know what your part numbers are and I will see what mine are and maybe you can cross reference them. Or if someone else knows....
Old May 23, 2014 | 06:00 AM
did you fix the bogging under load issue? if not, maybe give your cat a looksie.
also, when it isn't firing, is it cranking but wont run? or do you turn the key and everything shuts off?
Old May 23, 2014 | 02:06 PM
No I havent fixed the bogging under load problem but i think one of the cams may be a tooth out of time, it doesnt have a cat on it so I know thats not it. The other issue is its cranking but wont start but it only does it when its hot.
Old May 23, 2014 | 02:15 PM
Rokblock the toyota part # for the igniter pack is 896221-12050 not sure about distributer I will check. What days will u be in atl?
Old May 30, 2014 | 01:24 PM
This truck is draining me, I have done all that I know to do. I reckon its gonna have to go to the shop....I have put a new distribitor, new cap, rotor, plugs, wires, new ignition control module and stil sometimes it fires right up and then all of a sudden no fire. I have also checked and rechecked all grounds not sure where to go next. Any suggestions?
Old May 30, 2014 | 08:26 PM
rokblok's Avatar
AFM (air flow meter) has checked ok? TPS reading properly? These things won't kill the spark, but they could affect the bogging issue. Do you have a wiring diagram? Have you followed everything in the igniter circuit? Checked values at various places? Maybe there is a relay causing the no-spark?
Old May 31, 2014 | 04:27 AM
I have not dug in that deep yet. I know all fuses are good. I will chek relays today......
JonG85
Jan 18, 2023 04:31 PM
Naween Zohab
Nov 10, 2015 03:56 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
93RedKrawler
Sep 29, 2015 02:50 PM
