Sponsored by: CARiD
Need help fix rear axle gear seal leak
Old Jul 25, 2007 | 02:35 PM
1stRunner's Avatar
Help! Does anyone have any intruction how the change the rear gear seal for late 89 4runner. Thanks for your help.
Old Jul 25, 2007 | 02:47 PM
MudHippy's Avatar
It's commonly called a pinion seal. There's a good instructional on 4Crawler's site.
Click here:http://www.4crawler.com/4x4/CheapTri...eal/index.html
Old Jul 25, 2007 | 03:04 PM
1stRunner's Avatar
Thanks for your respond. And sorry, I may not make myself clear about the leak. The leak that I have is around the pan at the rear axle that have about 10 screw around it and I have no idea what it call. Sorry I not a mechanic, I just want to do it myself. Again thanks for your help.
Old Jul 25, 2007 | 03:12 PM
Elvota's Avatar
You are going to have to pull the axles, which requires disassembly of the drums and disconnection of brake lines, including E-brake cable.
There are four bolts at each end of the housing. Once brakes are out of the way, remove nuts and slide out each inner axle respectively.
Then you can remove the 10 nuts and pull the diff. Clean both surfaces thoroughly. Be careful not to scrape or gouge anything, that will cause a leak.
I'd recommend getting the orange Toyota RTV to reseal the diff to the housing. You don't need a gasket. Also, get a pair of inner axle seals from the dealer or Marlin. It's a good time to change them.
If you have many miles on your vehicle, this is also a good time to change the axle bearings. Around $45 each from the dealer, and will require a press.... but there are other methods that will work.
Might as well plan on a brake job as well.
A Haynes manual available from most autoparts stores will walk you through most of the step, at least with the brake... which is probably going to be the most frustrating part of the whole job.
Of course... this is assuming the leak is not from diff cover damage or impact. If so, the above won't be of much help.
Old Jul 29, 2007 | 10:46 PM
leonardator's Avatar
i never even took the tires off mine when i did it to my pickup, just jacked it up, unbolted the flanges and slid the tires away. and while you've got it out, you might as well weld it.
6th Gear
19
Dec 10, 2019 07:31 AM
DanStew
Jun 29, 2015 10:46 AM
Niameyrider
Jun 25, 2015 05:50 AM
Leonel
Jun 13, 2002 02:42 PM
