Sponsored by: CARiD
my temp gauge goes up then back to normal but nothing is wrong?
Old Oct 27, 2011 | 10:28 PM
Blacksmith's Avatar
Exclamation My temp gauge freaks out!!!
1986 toyota pickup with the 22ret
I start it up and drive away, after a couple minutes of driving the temperature gauge rises almost to the red, then falls back to normal within a couple of seconds. Everything seems fine so what does this mean? Is there something wrong or is it normal for it, but i don't remember it every happening in the past. Could it be a faulty temp sensor? Any ideas???
Old Oct 28, 2011 | 03:14 AM
paintthetown's Avatar
When was the last time you changed the thermostat and / or coolent? Don't buy a cheap thermostat either. Toyota thermostats are the best. And spend the extra $$ on the Toyota red coolent.
Old Oct 28, 2011 | 07:41 AM
Buck87's Avatar
A normal condition, don't worry about it and do a search on the subject.
Old Oct 28, 2011 | 07:47 AM
Buck87's Avatar
Follow and read. Good luck.
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
https://www.yotatech.com/forums/f116...s-fine-222937/
Old Oct 28, 2011 | 09:44 AM
Blacksmith's Avatar
i believe the thermostat is the original one still
Old Oct 28, 2011 | 10:42 AM
donomite49's Avatar
my 88 22re did the same thing. long story short, headgasket is blown. you may or may not have water in the oil. but it can also leak into the combustion chamber and out the exhaust. you might try some of the quick fixes/sealants. i ended up trying radiator flush and finished it off. then did a head gasket.
Old Oct 28, 2011 | 10:53 AM
Blacksmith's Avatar
I got the motor rebuilt 12,000 miles ago then i blew a head gasket and replaced the head gasket. The temp problem was doing the same thing before and after the head gasket replacement. But i also have notice that the rise of the temp occurs when i have the heat on!
Old Oct 28, 2011 | 11:23 AM
BMcEL's Avatar
READ:
Old Oct 28, 2011 | 11:40 AM
Blacksmith's Avatar
Now the link u guys keep providing me say its for the 22r and 22re but is it the same for the 22ret?
Old Oct 28, 2011 | 11:45 AM
BMcEL's Avatar
Yes. ..
Old Oct 28, 2011 | 02:46 PM
WHEELER8688's Avatar
I had the same problem and it was the thermostat
Old Oct 28, 2011 | 03:02 PM
BMcEL's Avatar
It is a known problem. Toyota even issued a technical service bulletin on it.
Old Oct 28, 2011 | 04:48 PM
Terrys87's Avatar
I agree with the Termostat that has been mentioned, but since we are on temperture gauge issues, I wanted to add another problem and fix that I ran into.
A while back I was mentioning that my wifes truck water temp guage was going from half way to cold. I actually forgot about it until I drove it today and it did it again. I pulled the water temp sensor and it had green corrosion on the sensor cleaned them with a brass wire brush and then I cleaned the contacts that goes to the wire as well with electrical contact cleaner. No more problems. Stays just below half as it usually does. I knew it wasnt overheating, but still like having a guage.
Here is a picture of a dirty Temperture Sensor. I have seen worse. I chipped some of the scale build up off so you could see a difference.
The sensor sits just below the Cold Start Injector in the Intake manifold. Uses a 17mm deepwell socket and is a 5 minute job.
Size:  64.8 KB[/QUOTE]
Old Dec 31, 2011 | 08:55 PM
Blacksmith's Avatar
Thank you i bought this part at the dealer ship and it fixed the problem. Thank u
Old Dec 31, 2011 | 10:07 PM
4runninmuds's Avatar
I had the same thing, up and then back down to normal. Mine wasnt too the red, maybe half way there but nonetheless, unsettling haha. Thermostat replaced, problem punched directly in the face. Good luck!
X2 on the toyota part as replacment
Ps. gotta love how easy it is to change a thermostat on a 22
bigjstang
Jun 2, 2025 03:56 PM
smiley52
Jul 11, 2015 05:16 AM
Avenged
Jul 9, 2015 07:55 AM
bryan34w
Jul 6, 2015 05:53 PM
wilbertd
Jul 6, 2015 07:39 AM
