Sponsored by: CARiD
my 4runner has a saggy A$$ (everything is new)
Old Oct 17, 2013 | 02:09 PM
cheftank's Avatar
its more like a gimp leg. Clearance on the rear tire to wheel well on drivers side is 7.5", passanger side is 6.75". I know each tire is different so I measured from the lower shock mount to the ground. Both are exactly the same. I measured from the upper shock mount to the ground, both are exactly the same. I measured both sides of the axle to the ground, both exactly the same.
I rolled around on the creeper for an hour checking body mounts and other "bushing" style items that might cause it to sag and found nothing (this was at night with a flash light so I may have missed something).
I'm at a loss of what to check next... any ideas?
important info on the runner: 1992 3.0L OME rear coils and rough country Nitro.0 shock less than 100 miles old. It DID sag on the factory suspension but I assumed it was just the worn out original shocks. Any ideas?
josh
Old Oct 17, 2013 | 02:11 PM
cheftank's Avatar
and just realized I posted this in the wrong section... crap
Old Oct 17, 2013 | 03:28 PM
HighLux's Avatar
tweaked frame?
Old Oct 17, 2013 | 03:58 PM
Bigblock's Avatar
So you have worn or incorrect rear coils or someone tightened up the torsion bars and made the truck LOOK like its ass is sagging.
Old Oct 17, 2013 | 04:16 PM
Teuf's Avatar
Body mounts........?
Old Oct 17, 2013 | 04:29 PM
rokblok's Avatar
If both of your rear upper shock mounts are the same distance to the ground, there can't be a sag. Unless your shocks are pointed towards center of vehicle and your measurement is a little off. Because 1/16" height difference at the center could be 3/4" at the fender lip.
But I'm going with rear coil sag. To common to be ignored.
Old Oct 17, 2013 | 05:31 PM
cheftank's Avatar
Coils are brand new. I'm going to check the torsion bar. I "eyeballed" the body mounts but didn't see anything.
Old Oct 17, 2013 | 06:07 PM
Teuf's Avatar
Body mounts kinda squish, enough to make an uneven sag.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
