Sponsored by: CARiD
"Master Differential Install Kit" OEM vs Aftermarket?
Old Apr 7, 2007 | 02:58 AM
Ron521's Avatar
Question "Master Differential Install Kit" OEM vs Aftermarket?
I'm going to be opening up the axle on my 2WD 22R which has a 4.11 gears and a noisey bearing, to replace bearings and install a set of Richmond 3.90 gears. Some catalogs and online suppliers offer "Differential Install Kits" consisting of bearings, shims, crush sleeve, etc, however the kit offered is different for OEM gears vs Aftermarket gears? Why? What is different about aftermarket gears that they require a different bearing/shim kit? Any light shed on this would be greatly appreciated.
Old Apr 7, 2007 | 09:54 AM
tc's Avatar
tc
Just different manufacturers include different things in their install kits. Actually, the Genuine Gear install kits are some of the best.
WTH are you going from 4.11 to 3.90 though? If you get the RPM's too low, you're actually going to HURT your gas mileage with the 22R...
Old Apr 7, 2007 | 03:56 PM
Ron521's Avatar
I'm changing the rear end ratio in part to lower RPM, and in part because a while back I replaced the 4 speed gearbox with a 5 speed. The 5 speed gearbox was out of a vehicle with a 3.90 or so rear end, so my speedometer is no longer accurate, reads considerably faster than true road speed.
Old Apr 7, 2007 | 04:57 PM
tc's Avatar
tc
Ohhhh - gotcha.
I would just put on bigger tires. LOL
Ladythump
22
Nov 9, 2015 08:53 AM
Sep 4, 2015 09:27 AM
Esibnitsud
Jul 30, 2015 08:21 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
Snort
Jul 19, 2015 07:03 AM
