Sponsored by: CARiD
lower to higher
Old Nov 25, 2012 | 09:14 PM
rubronthroad's Avatar
lower to higher
I am curiuos if anone has had any experience bringing a lowered truck back up to stock, if so please share.
Old Nov 26, 2012 | 06:08 AM
Robert m's Avatar
re-crank the torsion bars and pull out the blocks, done.
put stock spindles back in and swap lowering leafs for stock ones, done.
Old Nov 26, 2012 | 07:54 PM
Thanks Robert, I am looking for a 2wd and wanted to see what I would be getting into if a good deal came up for a lowered one, sound like its not that much work.
Old Nov 28, 2012 | 06:45 AM
BumbleYota's Avatar
This can be more to it. You need to know how it was lowered. Sometimes people cheep out and heat the springs to lower the front. Might have to swap the rear axle around too. If it's heated springs you will need new stockers. Either way its not too bad of a job. Also may need shocks and complete rear suspension. Some lowered trucks have notched rear frame and link suspension.
Old Nov 28, 2012 | 11:45 AM
Thanks Bumble, I may look for a truck that has not been lowered, and save myself some trouble.
Old Nov 28, 2012 | 12:08 PM
BumbleYota's Avatar
No problem. I've owned a couple dropped trucks and they can be a pain to reverse. Some are easy some aren't worth it. If it's a good deal and they can explain how it was dropped and still have the oe parts then it may be worth it. On the other hand it could become costly and thus defeat the good deal aspect.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
shredder4286
Oct 1, 2015 01:09 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
