Sponsored by: CARiD
Low/Rough Idle after oil change.
Old Jul 19, 2010 | 04:24 PM
Max OOOO's Avatar
Exclamation Low/Rough Idle after oil change.
Specs: '97 4runner SR5, 3.4 v6, 134,000 miles, 4X4
I just changed the oil on my truck today, and when I started it up (immediately after the change), the oil light went on for about a half-second, and then turned off, which seemed normal to me at the time. I let it idle in park for a minute or so while I cleaned up all of the split oil. I then poped it in reverse and noticed the RPMs went down to about 550 and the engine started shaking and ticking, like it was gonna stall. I backed out (giving it some gas), and parked and immediately turned off the engine. I've been afraid to touch it since.
I suspect that in park/neutral the RPMs are about 750, and in drive or reverse they drop to 550, I've double checked the oil level, the cap, filter, and plug, and everything seems to be in order. There are no loose hoses, or anything that may have caused a vacuum leak.
I need to drive about 300 miles tomorrow for an interview, so it would be nice to get this fixed tonight, and any and all advise is appreciated.
Old Jul 19, 2010 | 04:34 PM
brian2sun's Avatar
That's a strange one. Wrong weight oil? Filter not on tight? You're sure you drained the oil and not the diff or the tranny right? How full is it on the dipstick?
Old Jul 19, 2010 | 05:02 PM
Max OOOO's Avatar
I put in 5w-30 castrol gtx (same as I had in there), right up to the full mark, with a Toyota filter, and everything is nice and tight.
Old Jul 19, 2010 | 07:43 PM
Max OOOO's Avatar
Just went for a test drive. Things seem to be back to normal. phew.
Still kinda curious why this happened though.
Old Jul 19, 2010 | 08:12 PM
Teuf's Avatar
Gremlins.
Old Jul 20, 2010 | 04:09 PM
Max OOOO's Avatar
So today I'm driving to the store, everything seems fine, and then the CEL turns on and it starts running rough again. I think i'm running on 5 or 6 cylinders depending on my truck's mood.
I tried to get a code by jumping the diagnostics port, but the airbag, cruise, and abs lights just started flashing at different frequencies. What am I doing wrong?
Old Jul 20, 2010 | 04:12 PM
brian2sun's Avatar
Get the codes read at an Autozone, O'reilly's, etc.. for free or buy a scan tool for the future. Then let us know what it says and we can go from there.
Old Jul 20, 2010 | 04:15 PM
tblake88runner's Avatar
The autozone guys are great with this.
Old Jul 21, 2010 | 04:15 AM
krytellan's Avatar
As long as you have an OBDII car, otherwise, no.
Old Jul 21, 2010 | 04:52 AM
Lysmachia's Avatar
Silly question but did you double check the oil fill cap is on? Because the rough idle sounds like a vacuum leak...
Old Jul 22, 2010 | 08:41 AM
Max OOOO's Avatar
So I went into the mechanic... They read the code. I have a mis-fire on the #3 Cylinder, and they determined that the injector is kaput, and they wanted $600 to fix it, so I promptly left.
So, I guess my question is, how hard is it to replace an injector, and how much would a new injector run, price wise?
Old Jul 22, 2010 | 12:17 PM
brian2sun's Avatar
Hole 3 is a straight shot (you don't need to pull the intake plenum off) so $600 is insane. I've done an injector on theat side in a 1/2 hour. The injector was ~$80 for a rebuilt one I found at O'Reilly's. I'm sure a new OEM injector would be more, but I can't see it costing more than $200 total at a shop. It's not hard to DIY, but buy the upper and lower 0-rings for the other 2 on that side (I think the set was ~$5) because once you pull the fuel rail, you should replace all the o-rings to prevent it from leaking.
Old Jul 23, 2010 | 05:44 AM
93yota93lude's Avatar
ok this might be close to what im having go wrong right now... my truck idled really low and rough like a miss fire then i let it idle for a while and it got really rough and then back fired really loud then ran fine but when i would go to drive it and get around 3000 rpm it would retard out and pop and everything.. could i do a top engine cleaner run the can through the injectors maybe its clogged?
Old Jul 23, 2010 | 09:32 AM
brian2sun's Avatar
Yours sounds like an ignition timing problem to me.
Old Jul 23, 2010 | 11:54 PM
Armalite's Avatar
If he only needs one injector is it worth it to just swap that one out or send then in to be cleaned and tuned <=(couldn't think of the right word)?
Old Jul 24, 2010 | 02:55 PM
Max OOOO's Avatar
So I bought an injector ($116), and replaced it, I did the valve cover gaskets, and spark plugs while I was in there, and everything seems to be running well now. So it looks like it was just a coincidence that the injector failed immediately after I changed the oil.
Anyway check out what the plug in cylinder 3 looked like. (3rd from the left)
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
horunner1x
Jul 10, 2015 06:33 AM
