Sponsored by: CARiD
Low Compression on One Cylinder
Old Sep 29, 2007 | 08:53 PM
rowdy235's Avatar
Okay, so I know I have low compression on one cylinder (still don't know which one, just too lazy to test, suspect #2). Anyway, you can tell because of how it cranks, (excuse the lame sound effects)
It goes- cha-huh-huuuuh-huh-huuuuh-huh-huuuuh
Well that didn't really turn out well, but believe me it does have low compression on one cylinder. Anyway, could misadjusted valves cause this? I am asking cause I'm gonna have it in the shop tomorrow to fix my starter, and want to know if this is worth checking?
Thanks in advance.
Old Sep 29, 2007 | 08:58 PM
ozziesironmanoffroad's Avatar
YES!!!! GET IT CHECKED!!! could be the sign of a blown head gasket around that cylinder, bent or stuck valve, anything. could escalate into something serious pretty quick. get it checked.
Old Sep 30, 2007 | 08:44 AM
rowdy235's Avatar
I have practically eliminated blown head gasket because it doesen't smoke white, and it hasn't used a drop of coolant since I bought it 5000 miles ago. Its an easy job, so I'll adjust the valves today
Old Oct 3, 2007 | 07:30 AM
mr_will's Avatar
thats exactly what mine is doing in a 3.0. I think its the exhaust valve. I know for a fact its on number 6 though. I may pull the valve cover soon, but other than that the engine is getting replaced in spring so I am not to worried with it
Old Oct 3, 2007 | 07:45 AM
keithguts's Avatar
When the rig is running, does it miss at all, or does it miss every now and then?
Old Oct 3, 2007 | 12:02 PM
rowdy235's Avatar
it actually doesn't miss at all. It runs fine, accelerates good, I get 24mpg highway. Its just that when cranking over it sounds like low compression on one cylinder.
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
RatOmeter
Oct 22, 2015 03:17 PM
Sidherish
Aug 2, 2015 01:42 PM
TDonkey
Jul 26, 2015 10:14 AM
