Sponsored by: CARiD
Old Mar 30, 2016, 09:20 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Specifications & General Maintenance
Print Wikipost
Looking for low cost performance mods / 22re
Old Nov 24, 2012 | 02:14 AM
  #41
JDM4X4's Avatar
Supercharger
Originally Posted by gennro
About the 2 best mods for a 22re as for power is a cam and header with a 2 1/4 exhaust for the money. Then do the best you can for tuning by adjusting the AFM and bring timing up a bit. Other then that you are talking a lot of money to get one to make any power NA.
The best increase for the money is going turbo.
I agree with the idea of boost but i think it would be safer and more dependable to go with a supercharger. The cruddy part is cost either way, you can't just throw boost at a motor that old and not expect it to blow up. With the right build the motor can totally handle it.
Old Nov 24, 2012 | 07:49 PM
  #42
bob200587's Avatar
The 22re is like an old mule. It will carry what you put on it and can pull a little bit too;
But no matter how much money you spend training that mule, you still aren't going to be running in the Kentucky Derby.
Old Nov 24, 2012 | 08:00 PM
  #43
yodafan93's Avatar
i just adjusted my valves on my 22rec and saw a little improvement in mpg and improved torque curve. id give that a try. it only takes like 30 mins and is almost no cost.
Old Nov 25, 2012 | 05:41 PM
  #44
toastyjosh's Avatar
TB port as well as intake manfold. Not cheap but your past that now!
Look at LCE Performance
Old Jan 1, 2014 | 06:22 PM
  #45
wvtoyboy's Avatar
hands down, cheapest improvement to the 89-95 22RE trucks has got to be a gear swap. sure you can open the 22re up with headers and intakes, but youre not gaining much pulling power, which is essentially what they lack. find an extended cab 4x4 in the scrap yard or for parts that is equipped with a 22re and an automatic trans...odds are it has 4.56 gears. piece of cake gear swap with a huge improvement, even over 4.10's.. as someone said "22RE's like to be run at WOT"...and i cant think of a better way to keep them there....
PS...been running NGK plugs for 20 years in these trucks and haven't found a better plug for them
Old Jan 1, 2014 | 07:12 PM
  #46
lobukbuild's Avatar
first post 2007, 6 yr old thread. ?? ill join in. ngk, yes, the old regular basic plug. the newer ngk claim to fames, not so much. basic ac plugs work as good if not better. a 5th injector will get you a little more go as well!
Old Jan 3, 2014 | 02:57 PM
  #47
mitutoyo's Avatar
These engines usually generate a lot of power-robbing carbon buildup around the intake valves, intake manifold, throttle body, and injector tips. Take care of those things first for the cost of a couple of cheap gaskets and a can of seafoam. I would personally take it a step further and get my injectors checked out.
Old Jan 18, 2014 | 01:18 PM
  #48
lobukbuild's Avatar
as far as the 22re motor and low cost mods i can only recommend a 5th injector! bigger mass air flow, battery/air box flip (efi 22re), bigger/better air filter and carb tuning (22r), quality but basic plugs cap rotor wires, good exhaust, egr delete, proper gears. compression is to low to do much of a cam upgrade and if you shave the head to raise compression it just beats the crank and rods up. lets face it, theyre just small 4 cyl motors designed for pick ups, so dont expect much. keep it maintained and regear according to your intended use and tire size will be you best bet. i geared mine for normal road use (4.88) and added the 4.70 gear in the t/case and lockers for offroad. 22 r series are great motors known for longevity not power. however im not saying that if you were to build one from the ground up with enough money you wouldnt have an impressive motor, it just depends on how deep your pockets are. newr low mileage motors of today might have more tuning options with better results over the famous 22r /re
Old Jan 18, 2014 | 04:26 PM
  #49
Barry&Amanda's Avatar
Originally Posted by simpleblue
I like the Oil Idea... I will try that....
Try Ow oil I used it and it's noticeable
Old May 7, 2017 | 04:56 AM
  #50
jpcedotal's Avatar
Great Thread Guys & Gals
There are some things I want to do to my 94 4x4 Ext cab. She gets me back and forth to work, my deer stand, and pulls a 87 bassmaster classic 373 to a couple of local lakes. It is completely stock and I am old enough to know the best way to drive it is with alot of TLC.
jbv808
Aug 6, 2021 04:47 PM
Eggslinger
Jun 8, 2019 03:32 PM
May 20, 2016 10:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
Nickdigg
Jul 7, 2015 06:04 AM
