Sponsored by: CARiD
Looking for Advice on Maintaining a recently purchased 1993 4x4 v6 truck.
Old Jun 26, 2009 | 10:52 AM
rpl's Avatar
rpl
Long time lurker, first time poster.
Any ways here is the rundown.
1993 4x4 ext-cab Toyota V6 Auto.
177k on the OD
Engine was "rebuilt" at 170k in sept 08.
New Radiator (Does look new) also
A check of the glove box reveals pretty much all the receipts since 1993 (including the bill of sale).
Head Gaskets done at 88k (under warranty according to the recipt)
I'll need to go over them again but I didn't see anything about a TB + WP replacement but I assume it was done..
The individual I purchased it from kept if from about 10 months then drove if from Washington State to Texas w/out any issues, It's been sitting pretty much graged for a few months until I bought it.
The only thing I noticed was that the Coolant res was right at the LOW mark. I Checked the Radiator and it's topped off (even after sitting all night the levels didn't change). When i drove it home (about 60 miles) I didn't notice
any heating issues the gauge read just below 1/2 way.
As a side question, since I am not sure what mix+radio was originally in there (it's the green stuff not the pink btw) I should drain/flush the entire radiator and just refill from scratch correct?
With all that being said, everything seems pretty good in it, HOWEVER I plan to use it for camping and would be in some pretty out of the way places and
don't want to be stuck out. I plan on taking it to a local Toyota speciality shop, Here is what I think they should probably look at..
- Inspect current head gaskets
- check the radiator (since i noticed the reserve was low)
- check Timing Belt / Water Pump
- Tranny?
Anything else I need looked at? Done?
Thanks.
Old Jun 26, 2009 | 04:10 PM
KVRunner's Avatar
Should be able to add a little water or coolant to the reservoir. It wont hurt anything if you dont have an exact 50/50 ratio of water to coolant.
Old Jun 27, 2009 | 06:14 AM
wheatus's Avatar
buy one of those cheap antifreeze testers at an auto parts store.
justdifferentials
14
Jun 11, 2017 08:36 PM
dbollier123
Sep 29, 2015 05:23 PM
whiteyota93
Sep 29, 2015 02:31 PM
Cycles
Sep 29, 2015 06:37 AM
taraf
Sep 25, 2015 02:57 PM
