Sponsored by: CARiD
Little filters on valve covers?
Old Jan 8, 2013 | 12:01 PM
Cthulhu's Avatar
Saw a couple YouTube videos where guys had these little filter like things on their valve covers? What do they do? Eye candy?
Old Jan 8, 2013 | 12:14 PM
Scirocco16v's Avatar
I beleive they are replacing the PCV...ok on carbs, have "heard" not ok on EFI
Old Jan 8, 2013 | 04:11 PM
rokblok's Avatar
If its a stock valve cover, it has two vents. One is PCV (positive crankcase ventilation), and is located at the rear of the valve cover, and has manifold vacuum applied and controlled by a valve, the PCV valve. The other is at the front, and it connects to the stock air filter housing for burning the crankcase fumes that the PCV doesn't get, and/or to draw air from the air cleaner(clean air) for the PCV system(primarily).
The little filters you see on the vids is just primarily to filter the air coming into the valve cover/PCV system, bypassing the air cleaner. You'll probably notice they don't have stock air cleaners also...
Old Jan 8, 2013 | 04:24 PM
bone collector's Avatar
i have a 3vze EFI with a filter on the valve cover. I used it to replace the hose that goes into the air intake tube. i built a custom ISR on my truck and didnt want to drill into the new pipe so i used the filter. check your facts. nobody replaced the pcv. check your facts a lot before you say such ridiculous stuff.
Old Jan 8, 2013 | 05:15 PM
Teuf's Avatar
Subscribed, wanting to see a picture of this set up.
Old Jan 8, 2013 | 06:20 PM
Check my build thread. you can see pics of this set up
Old Jan 8, 2013 | 07:47 PM
Teuf's Avatar
OK I mean pictures on a 22re.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
