Sponsored by: CARiD
Lift Springs
Old Apr 10, 2011 | 10:20 AM
patricklikesbeer's Avatar
Lift Springs
I have looked a long time on the net to find the answer to this, generally i can find a answer to a question but this one i have been lacking on. On the 89-95 trucks dose anyone make a lift spring for the rear (prefer 3inch) that is the factory 51inch, and would be flexy. I also gather the 96-00 taco's are the same length. I cannot believe that no one makes these.
Old Apr 10, 2011 | 11:01 AM
Junkers88's Avatar
What year is your truck?
Seeing that you're in Nova Scotia I don't know of anyone there that offers lift springs but someone on here might know of a manufacturer.
Tried looking at Wabbit's site yet?
Link. http://www.wabfab.org/
Also wanted to let you know that there are other options than just replacing the leaf springs. You can add coils to the rear (ZUK mod, search on here), blocks (not really recommended with the factory worn out springs but it has been done) and longer shackles (again not recommended with the worn out leaves).
You can also have a custom set made to do exactly what you want from these folks. http://www.alcanspring.com/
Welcome to Yota Tech!
edit: Want to add here that the recommendations of not using blocks or longer shackles doesn't come directly from me. I've never used either but some folks on the board advise against using them due to added strain on already tired leaf spring packs.
Old Apr 10, 2011 | 11:11 AM
skypilot's Avatar
OME medium springs, bushings, and rear shackles.
The 18mm bolts come from marlin Crawler, just drill out your current flanges.
Working on my truck for a while now, over 10k miles.
Flying91
45
Apr 11, 2024 04:39 PM
nvdesertrunner
May 11, 2020 08:18 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
mavenator
Aug 13, 2015 01:12 AM
coffey50
Jul 28, 2015 10:55 AM
