Lift
Lift
I just ordered a 3inch lift for my yota
It is coil spacers and add-a-leafs. I was wanting to see pics of yotas with similar lifts. Also what is the biggest tire size i can fit 32x11.50s maybe?
Thanks, Clayton
It is coil spacers and add-a-leafs. I was wanting to see pics of yotas with similar lifts. Also what is the biggest tire size i can fit 32x11.50s maybe?Thanks, Clayton
I assume you have a pre 96 Taco? The 32's will work fine. No 33 though. THey will rub in the rear. These are pic's of a 99 with a Revtek 3" with 285/75R16 (33")
Really didn't likethe spacers so I went with adjustable coil overs later. Good luck.
The width is the major problem. There's a guy running 35x10.50's at stock height, but it looks like he gets pretty significant rubbing at full stuff. I run 33x10.50's on stock height with NO rubbing.
I don't think you'll fit 33x12.50's with 3" lift without some body trimming.
So, depends on what look you want - if by "big" you mean wide, probably something like a 31x14.50. If by "big" you mean tall, 35x10.50.
(of course, if you have 16" rims, you'll have to look up the specs for the metric sizes - sorry bout that)
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
