Sponsored by: CARiD
Lift
Old Jan 2, 2006 | 07:51 PM
muddybamayota88's Avatar
Lift
I just ordered a 3inch lift for my yota It is coil spacers and add-a-leafs. I was wanting to see pics of yotas with similar lifts. Also what is the biggest tire size i can fit 32x11.50s maybe?
Thanks, Clayton
Old Jan 2, 2006 | 07:58 PM
964runner's Avatar
search
Old Jan 2, 2006 | 08:03 PM
oly884's Avatar
Guest
as for pics, the search would probably be your best friend.
as for tire size, 32's would fit no prob, you could probably fit 33's with the right back spacing as well.
welcome to YT!
Old Jan 2, 2006 | 08:05 PM
ecchamberlin's Avatar
I assume you have a pre 96 Taco? The 32's will work fine. No 33 though. THey will rub in the rear. These are pic's of a 99 with a Revtek 3" with 285/75R16 (33")
Really didn't likethe spacers so I went with adjustable coil overs later. Good luck.
Old Jan 3, 2006 | 06:09 AM
tc's Avatar
tc
The width is the major problem. There's a guy running 35x10.50's at stock height, but it looks like he gets pretty significant rubbing at full stuff. I run 33x10.50's on stock height with NO rubbing.
I don't think you'll fit 33x12.50's with 3" lift without some body trimming.
So, depends on what look you want - if by "big" you mean wide, probably something like a 31x14.50. If by "big" you mean tall, 35x10.50.
(of course, if you have 16" rims, you'll have to look up the specs for the metric sizes - sorry bout that)
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
