Sponsored by: CARiD
no brakes!
Old Dec 31, 2005 | 12:16 PM
kodit0103's Avatar
no brakes!
Hey guys whats up? A friend of mine put engine oil in his brake fluid on a 91 4runner,4wd, v6. WE changed the master cylinder, wheel cylinder, calipers, pads and shoes. At the same time, we noticed a leak in the powers steering pump. WE went ahead and changed it. I have been trying and trying to bleed to system now, but i think there is still air, or i am not doing something right. I have never bleed a M/C, how long does it take to get pressure? Do you have to pump and bleed for a long time? I at some point I had pressure in the valve thats on top of the rear axel, but no more. Is changing the power steering pump related at all with us not being able to get pressure in the brake lines? My friend is helping me with the bleeding, should i get one of those bleeding tools? thanks guys!!
P.S. i have bleed brakes in the past, and my father was a mechanic for 30 years, so i grew up around cars, i just havent worked with toyota that much, not sure if i was missing something, thanks for all your help
Old Dec 31, 2005 | 12:47 PM
midiwall's Avatar
When you bleed, remember that you have to hold the pedal down while you close the bleeder valve at each wheel. Past that, bleed from closest to farthest (driver's front, passenger front, driver's rear, passenger rear).
Old Dec 31, 2005 | 01:39 PM
UKMyers's Avatar
Oil in the brake reservoir.... that's a new one Do you have any leaks anywhere that is letting air in? It shouldn't take too long to get enough air out to at least have some pedal. Good luck with that one...
Old Jan 1, 2006 | 08:08 AM
Robinhood150's Avatar
Don't forget to bleed the LSVP too. It's the valve above the rear axle. I believe it's done last in the sequence.
Old Jan 1, 2006 | 10:08 AM
kodit0103's Avatar
brakes, please help working now!!!!
Hey guys whats up? Happy new Years! 91 4runner v6,4wd,rear wheel ABS,A/T. So we changed the M/C, wheel cylinders, calipers, shoes, and pads and POWER STEERING pump all at the same time. We now have a little pressure on the valve on top of the rear axel, and a little pressure on the calipers. the brake pedal is soft. WE bleed the M/C before installing it. WE are not getting fluid to the rear wheels. PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE HELP!!!!!!!!!!
Old Jan 1, 2006 | 10:13 AM
eric-the-red's Avatar
Did you bench bleed the master before installing it, if not air can get trapped in the end because of the way it slants upwards.
Also if you have rear ABS then there is a special tool for bleeding the power steering system. The ABS uses pressure from the power steering system to activate. I don't know exactly how it all works but it could have something to do with no brake pressure.
Old Jan 1, 2006 | 10:22 AM
Yota4runner's Avatar
Did you bleed the entire system?, you may have an air pocket in the line somewhere thats blocking flow.
I assume you've checked for any major leaks in all the lines and what have you?
Old Jan 1, 2006 | 10:25 AM
steelhead's Avatar
Get a brake system pump and bleed the whole thing aggresively. then let us know.
Old Jan 1, 2006 | 10:26 AM
AW1090's Avatar
yup, maybe take off the mc and do another bench bleed....check for leaks and bleed the entire system...
Old Jan 1, 2006 | 10:49 AM
kodit0103's Avatar
thanks guys, just got back from getting a pump, i'm going out there right now, hope it doesnt rain!! Bench bleed the M/C this morning, but when i installed the brake line, it felt like air rushed into the M/C again!!! should i take it off again?Thanks guys
Old Jan 1, 2006 | 11:08 AM
midiwall's Avatar
Why did you start another thread? For the purposes of continuity and later helping others when they search, it's REALLY important to keep all the information in one spot...
https://www.yotatech.com/forums/showthread.php?t=75154
Old Jan 1, 2006 | 11:32 AM
Bob_98SR5's Avatar
kodit,
yes, mark is right: keep your topic continuous in one thread.
thread merged
bob
Old Jan 1, 2006 | 01:12 PM
kodit0103's Avatar
Hey guys, so i am bleeding the whole thing again, but it is REALLY hard for me toget any fluid to the back tires. Any suggestions? By the way, i want to check leaks, whats the most efficient way?
Old Jan 4, 2006 | 08:03 AM
colsoncj's Avatar
sounds like your lspv may be clogged or stuck....
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
