Sponsored by: CARiD
life of an OME shock
Old Oct 8, 2006 | 08:52 PM
snoozer's Avatar
How long do OME shocks typically last before needing replacement?
Old Oct 8, 2006 | 09:17 PM
bktaco's Avatar
i replaced my tacoma shocks at about 100,000 miles. they were fading and i could have probably gotten a bit further, but i was all into the big maintenance routine so i did that too. my guess is that it all depends on the amount (and type) of offroading you do. does your rig bounce more than once? a good shock should basically stop your truck from cycling more than once (up and down). you can check it by jumping on one corner bumper.
Old Oct 8, 2006 | 10:56 PM
Elton's Avatar
got 137k on the stock shocks and a little over 167k on the 91 i had and i need to find someone to do the ones on my 98
Old Oct 9, 2006 | 10:54 AM
Mikestang's Avatar
I think he means Old Man Emu (OME), not OEM.
Old Oct 9, 2006 | 11:23 AM
bktaco's Avatar
ahhhh, i c. arent those OME shocks typical gas charged design? i was refering to my bilstiens (OEM), but they also are gas charged, and i would think have a similar life cycle. still probably comes down to amount and type of use. also the jump test will suffice for any shock.
Old Oct 9, 2006 | 12:49 PM
Paul H.'s Avatar
OME's come with lifetime warrenty I believe.
Old Oct 17, 2006 | 07:35 AM
Squiddy's Avatar
OME shock stuff
Current warranty is 2 years on the shocks, at least per the kit I just got. My stock Toyota ones blew around 100-110 K, so I'd expect the OME ones to last as long.
choppe777
May 16, 2016 08:00 AM
mistershmi
Jan 5, 2016 11:07 AM
Swampwalker
Oct 12, 2015 09:49 AM
sonorn67
Sep 19, 2015 05:39 PM
justdifferentials
Sep 5, 2015 06:52 PM
