leaking antifreeze at thermostat housing.
Old 05-29-2011, 12:52 PM
deano1982's Avatar
Hi all. I recently replace my thermostat on my 1990 22re truck. Now it is leaking at the thermostat housing. I used the rubber O ring on the thermostat and tightened the bolts as tight as I am willing to do. Should I try some rtv instead of the O ring or make a gasket and discard the O ring altogether? Anyone else have this issue? Thanks in advance.
Deano
Old 05-29-2011, 12:59 PM
xxxtreme22r's Avatar
use the o-ring and water safe RTV.
Old 05-29-2011, 09:49 PM
wyoming9's Avatar
Smile
Did you clean both surfaces real well as long as the neck where the hose goes.
I always use rtv and the grommet o ring and a new hose if it shows any signs of wear
This is after at least one or both bolts break off and need to be repaired.
Never seize is your friend
Old 05-30-2011, 06:41 AM
swampfox's Avatar
Did you clean the area where the thermostat sits ? mine had a crust built up in the lip.
trailgoat
08-13-2015 05:54 PM
jjrbus
07-27-2015 11:06 PM
kcaudill
07-20-2015 12:06 PM
andrewtexas123
07-14-2015 04:29 AM
Jonny246
07-12-2015 04:51 AM
Quick Reply: leaking antifreeze at thermostat housing.
