Sponsored by: CARiD
Jeggs lift blocks?
Old Jan 28, 2012 | 07:08 PM
mommucked's Avatar
Jeggs lift blocks?
Does anyone know if Jeggs blocks pt#60811 will fit on 84 pickup spring perches correctly? I've heard some hollow blocks can pop out because of the rounded top edges on the perches.
Old Jan 28, 2012 | 07:26 PM
yotaman85's Avatar
Lift blocks kill babies....
Old Jan 28, 2012 | 08:15 PM
ThatGuy1295's Avatar
Don't use hollow blocks, especially shucks brand aluminum blocks. If you have to use a lift block don't go more then 2'', and get steel blocks with or without a slight taper. Theres over a thousand of them out there, why are you asking about "JEGS". Use a measuring tape and check the dimensions of the part to the application. And if it doesn't list applications or dimensions then don't waste your time.
Old Jan 29, 2012 | 04:43 AM
mommucked's Avatar
I've had 3" tapered, solid Iron blocks on my truck for years. Worked Ok after I installed some old style NWOR traction bars to combat the axle wrap. But I recently discovered my pinion angle is off. I'm looking for some flat 2" blocks to put under my 2" rear springs. This is a mud/hunting/firewood truck, not looking for extreme articulation. Who makes sells this recomended type of block for Toyotas? Jegs lists 84 toyota for this part but i don't like the looks of the hollowed out alum. spacers.
Old Jan 29, 2012 | 06:31 AM
E-ROC's Avatar
Old Jan 29, 2012 | 09:06 AM
http://fatbobsgarage.com/c-200440-li...lock-kits.html
Theres some good ones in here. There hollow, but the cast iron. Wich is fine, when I said don't use hollow blocks I was referring to aluminum. Should have said don't use aluminum. Sorry for the confusion.
Old Jan 29, 2012 | 09:09 AM
And do you think you need a tapered block to correct your pinion angle?
I have a 2.5 solid steel block with about a 4 degree taper. Cant for the life of me remember were it came from, but ill work on it.
Old Jan 29, 2012 | 01:08 PM
bob200587's Avatar
Sep 4, 2015 09:27 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
