Sponsored by: CARiD
installing rear leaf spring help
Old May 15, 2014 | 04:54 AM
BulletProof86's Avatar
Hello,
I have a 1986 Toyota Pickup 4x4 and I am trying to swap in new rear leaf springs. I had problems getting the bolt out of the hanger (frame to leaf sorting mount), a common problem it seems. I tried using rust catalysts,a breaker bar, impact gun, and heating up the hanger, no luck. I ended up cutting the bolt out but also cut the metal sleeve on the bolt. Does anyone know where I can get a new sleeve? Or can I go with a larger diameter bolt without a sleeve?
The dealership said they could order the part for $80 but that seems outrageous.
Thanks,
Gary
Old May 15, 2014 | 07:50 AM
thefishguy77's Avatar
When you say hanger. Do you mean the shackle it self or the shackle mount got cut? If you can take a picture or 2 it would help us tremendously. If you cut the shackle I can't imagine new ones being that spendy. But they might be. The leaf spring connects to the shackle to the shackle mount, and the shackle mount to the frame. What part did you accidentally cut?
Old May 15, 2014 | 10:33 AM
wyoming9's Avatar
Red face
Just what are you trying to do??
The bolt and sleeve get so seized they never come out. No matter what one tries
Your new springs do not have a bushing??
Are you going with used springs that you need to replace the bushings??
Old May 15, 2014 | 10:37 AM
I'm at work right now but I'll upload pictures when I get home.
Old May 15, 2014 | 10:44 AM
The springs I'm installing are new and came with bushings, but no sleeve. So the bolt will not fit snug in the bushing.
For clarification I had to cut the bolt to get the spring off and ordered new ones from the dealership but the dealership wants $80 for the sleeve.
Old May 15, 2014 | 10:49 AM
scuba's Avatar
Front spring hanger. Not the shackle at the rear if the spring.
Try All-Pro Offroad.
They sell the sleeves to take an M18 bushing ID down to M17.
Old May 15, 2014 | 11:00 AM
wyoming9's Avatar
Red face
I have never seen new bushings with out the sleeves in springs .
Go figure learned something new.
Old May 15, 2014 | 01:56 PM
Here are some pics of what I'm talking about. The one title sleeve is what I cut. In that pic (from outside to inside) you see the leaf spring, bushing, sleeve, then bolt. I need a new sleeve.
The second pic titled hanger is the location where the spring mounts.
Thanks.
Attached Thumbnails installing rear leaf spring help-sleeve.jpg   installing rear leaf spring help-hanger.jpg
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
