Sponsored by: CARiD
im having issues..
Old May 17, 2011 | 02:10 PM
camule's Avatar
im having issues..
ok well i was riding down the road and the 89 yota pick up just dies well after i inspected the fusses found that my efi fuse was busted and i replaced it the truck once again started no problems..a day or two later it does it again and this time it is just blowing fuses and will not even try to start..i have replaced the efi relay and still blowing the fuses what else could it be what else does that fuse run?
Old May 18, 2011 | 06:44 AM
perushing's Avatar
Check your wires that the fuses go to or run from. I had this problem with my taillight fuse. It would blow it like right as soon as I put it in or shortly after. One of the wires was exposed and grounding out.
Just check your wires is my bet
Old Feb 9, 2012 | 09:07 AM
bjlambert's Avatar
I just had this problem, my O2 sensor wires were touching my exhaust, and melted together causing it to short out, and somewhere along the lines blew my EFI fuse. 5 minuite fix with good old electrical tape!
Old Feb 9, 2012 | 04:13 PM
wyoming9's Avatar
Red face
Well I don`t have the manual for the 89 but do have the one for 88 which should be close
:jessica: The EFI fuse powers the ECU, Circuit opening relay, Air Flow Meter, VSV, and Oxygen Sensor.
Pretty much could be a short any place fuel pump wires pump itself.
Get the Meter and start checking.
Old Mar 1, 2012 | 05:53 PM
walker3288's Avatar
help
i have and 85 22re p/u i just bought, not running. i am getting some fuel to the fuel rail but the efi fuse keeps blowing. ive checked the maf and 02 sensors. it will run with starting fluid. could the fuel pump still send some gas if it is shorted out and maybe it just doesnt have enough pressure?
Old Mar 1, 2012 | 05:54 PM
walker3288's Avatar
and i also checked the codes and it showing code 2
MaltDisney
44
May 8, 2014 01:27 PM
Dexter350k
Sep 11, 2013 05:20 AM
norville
Aug 30, 2013 04:06 PM
WesNile
Nov 20, 2012 08:33 AM
