Sponsored by: CARiD
IAC valve question
Old Oct 7, 2009 | 09:04 AM
NassauBob's Avatar
IAC valve question
So I took my truck in for - among other reasons - sluggish acceleration from 0 to cruising speed. The tech came back to me with idle air control valve needs maintenance'd, or something to that effect.
If this is the correct diagnosis, is this something I can do myself, with typical garden-variety home tools, and will I be able to notice a difference when I am done?
Old Oct 7, 2009 | 10:19 AM
brian2sun's Avatar
Pretty routine maintenance. I clean my throttle body/IAC every spring. It's a good idea to run by your dealership and pick up a throttle body gasket and an IAC gasket ($10 - $15 for both) because they are cheap. Some people just reuse them, but I like to replace them. Search IAC cleaning and you'll find info on how to do it. You'll need some carb cleaner, rags, a screwdriver, some RTV silicone sealant and a little elbow grease.
Old Oct 7, 2009 | 04:47 PM
myyota's Avatar
What year truck/4Runner do you have, and what engine ?, theres two diferent styles of idle air control valve for a 22RE depending on the year of the engine, and if its a 3.0 im not sure about the idle air control on it.
smthwsn357
May 1, 2024 07:28 AM
thefishguy77
Jul 30, 2015 10:59 AM
Poppie51
Jul 23, 2015 05:03 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Poppie51
Jul 16, 2015 06:16 PM
