I need help, 22re Running bad
Double check distributor timing and chain timing marks.
Check spark plug wire order.
Scan over entire electrical system for unconnected plugs.
Re check all vacuum hoses for proper routing from one end to the other.
Oil level?
Intake system is tight and no air leaks.
No offense with this one: everything you unplugged needs to be checked.
Oil level?
I had 1 and 4 cylinder TDC, with my crank pulley at the 5 marker and my timing gear at 12 just a tad to the right because of teeth. i had the dist wired corect.
vac lines are good. there are two greyish plugs near the injector plugs that i couldnt find homes for and now #3 injector is leaking
