Sponsored by: CARiD
I keep breaking my truck! Help me fix it
Old Oct 19, 2011 | 05:36 PM
starr_scream's Avatar
Exclamation I keep breaking my truck! Help me fix it
I drive a 99 4runner s5 6 cylinder 4wheel drive
Yesterday I noticed a small vibration in the truck while I was driving. I could feel it under my feet.
Today it is worse. I haven't driven it much. It vibrates when I'm driving, when I'm idle or when I'm in park. The check engine light is flashing now. (the check engine light is always on solid) I can only assume when it's flashing it really wants me to fix it! When I got out of the truck I noticed a little burning smell. It's night and pouring rain, so I couldn't tell if there was any smoke or not.
What could be causing this, I need to fix it asap!
Thanks everyone =)
Old Oct 19, 2011 | 06:09 PM
JBurt's Avatar
Pull the codes. That will give you a good place to start. It could be a lot of things.
Old Oct 19, 2011 | 06:12 PM
lftd_86_yota's Avatar
Are you describing a misfire? If so, the check engine light is flashing beacuse the misfire is occuring at such a rate that the catalytic converter could be damaged as a result. Hope this helps.
duckhead
170
Nov 13, 2017 06:07 AM
voiddweller
19
May 2, 2016 09:10 PM
odonekanobe
Jun 26, 2015 02:27 PM
saphirekosmos
Jun 22, 2015 10:26 AM
