I have no spark???
Old 04-18-2011, 04:16 PM
Webster93's Avatar
I have no spark???
I have a 1993 Toyota 4Runner and i cant get it to spark, i have all new spark plugs, relaced my distributor cap and rotor, then replaced my ignition coil and my igniter.... and still no spark, i have no idea what to do next, any suggestions???
Old 04-18-2011, 06:48 PM
peow130's Avatar
check connections? wiring? etc etc
Old 04-18-2011, 06:57 PM
YotaWoRx's Avatar
check the signal rotor air gap in the distributor. also chk the resistance of the signal rotor to specs.
Old 08-05-2011, 03:36 PM
blynch35's Avatar
i just had the same problem with my 93 4runner 3.0 as it turned out my air flow meter went bad on me. to check if thats the problem deconnect the plug and try to start it. if it starts (it will only run for a few seconds) your meter is bad. i had just replaced plugs,wires,cap,rotor,trans fluid and filter,oil and filter,fuel filter,timing belt,water pump,both pullies,drive belts,all raidator hoses,flushed raidator and installed a cold air intake and now a used air flow meter i got on ebay for 40.00. i hope thats it for now it only has 102,000 miles on it. buy the why this was all done thanks to you guys here thank you
zytra
01-24-2019 03:16 PM
Kamaloha
10-16-2015 05:13 PM
shredder4286
10-01-2015 01:09 PM
voiddweller
09-28-2015 11:21 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: I have no spark???
