Sponsored by: CARiD
How much lift to run 31" tires?
Old Dec 3, 2009 | 07:37 PM
86yota2wd's Avatar
I know this probably has been gone over already but I was wondering how much net lift I would need to run a 31*10.5*15 tire with a 15*8 wheel with 3.75 of backspacing. I know that I can get a lift spindle and bj spacer with each respectively 3" and 1.5" of lift I was also thinking about the fabtech uca which should give me about 2-3 inches. For the rear i was thinking about a chevy 64" swap for added travel but i am open to other options i want to keep street reliability since this is my dd.
Thanks in advance!
Old Dec 3, 2009 | 07:44 PM
91_TOYOTA_4x4's Avatar
ok i bet you have got this before but why are you lifting 2wd? besides that i would say go 2 or 3 inches and maybe use some 4wd yota 51" leafs for the rear.
Old Dec 3, 2009 | 08:09 PM
86yota2wd's Avatar
i just want a little more ground clearance and want the availability of a road snow/all terrain tire. and i haven't run into many problems with wheeling mine currently even without a locker... i made it up a road a 4 wheel drive ford had to go around something. plus i want a step up to building it into a pre runner thats half the reason for the chevies. and i don't really want to go buy a new truck because i've got a pretty rare model for what i'm told
Old Dec 3, 2009 | 08:33 PM
peow130's Avatar
well you have a few options for the rear.
you can do a SOA swap, which requires welding...
orr..
you can do a leaf swap.. which requires welding.
idk much about the front, but i know you can get balljoint spacers and net 1.5" of lift from those.
Old Dec 6, 2009 | 12:15 PM
86yota2wd's Avatar
I think i've decided on a set of chevies but i'm not sure how much lift these will give me. i'm not looking to jack it up way high because that is pointless but i want to fit some bigger tires under and have a little taller truck.
Old Dec 6, 2009 | 12:23 PM
camo31_10.50's Avatar
have you tried to find a set of S-10 or Sonama ZR2 rear leaves??? they are spring under axle just like your 2wd toyota..but they have quite an arc in them and they flex pretty good (at least on the s-10 i drove for a couple days they did)..
or you could try the 63" 2wd chevy leaves with the overload removed and that will net a 4wd truck around 3" of lift..so i suspect it would net you the same about
Old Dec 6, 2009 | 12:41 PM
Ezrider_92356's Avatar
for the front, 3inch lift spindles and a 2 inch body lift or 1.5inch bj spacers should get you in 31's with the right backspacing, flared fenders would go along way in preventing any rubbing
Old Dec 7, 2009 | 07:28 AM
86yota2wd's Avatar
unfortunately my truck is an automatic and it makes it a pain to work with so i think i am going to go with the lift spindle and the bj spacer combo... i want to run the lift spindle but i've heard some mixed opinions on them.. any out there?
what are the pros and cons. etc...
BushPig
Oct 29, 2022 06:26 AM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
