Sponsored by: CARiD
how high does your truck sit with X lift
Old Jul 3, 2009 | 10:48 AM
greatskiiiier's Avatar
i want to get an idea for how high my truck will sit with a 1,2,3 inch body lift... as it sits its "stock" but the guy i bought it from said theres an AAL in the rear, and from the height of it- i truly i believe i can clear 33" tires with no rubbing at all
i dont want anyone calling me a newb about this- i just want to see what your truck measures from top lip of the rim to the bottom of the fender
i couldnt find many pictures of this, but the only one i found was a "3inch body lift" and my rear sits 1/2 inch higher and my front sits 1/2 inch lower- i checked the body/frame link points and there is nothing in there (so no BL)
Old Jul 3, 2009 | 11:17 AM
4Crawler's Avatar
Stock height up front is 13.5"-14" rim-fender:
http://www.off-road.com/trucks4x4/ar....jsp?id=398514
Add an inch to that for each inch of body or suspension lift.
Old Jul 3, 2009 | 01:05 PM
Teuf's Avatar
mine is 16 inches or so with a 3" lift
Old Jul 3, 2009 | 01:47 PM
just the info i was looking for- ill edit the post after i measure for a 2nd time
front was 14 the rear was 15
Old Jul 3, 2009 | 03:00 PM
just cranked down on the torsion bars- now it sits 14 7/8 on all all corners... now im ready for some 33x10.5s
Old Jul 3, 2009 | 05:47 PM
KVRunner's Avatar
Be prepared for it to ride like a lumberwagon
Old Jul 4, 2009 | 02:38 AM
Teuf's Avatar
Get a set of BJ/s , cheap mini lift, not as harsh a ride as the torsion crank. Lumberwagon is being kind.
Old Jul 4, 2009 | 04:02 AM
by going up 7/8? i thought you were safe up to an inch- going in and out of my driveway the truck actually feels a bit more stable
Old Jul 4, 2009 | 10:55 AM
KVRunner's Avatar
Any cranking on the torsion bars will stiffen up the ride. Not saying that it is not safe, just saying that it is going to ride alot stiffer. If you buy a set of ball joint spacers you can actually relax the torsion bars a bit which will make for a lot better ride than cranking the torsion bars.
Old Jul 4, 2009 | 06:40 PM
driving the truck today and it feels the same- i even joked to a friend that you guys must only drive BMWs because even after "stiffing up the ride" the truck is smoother than most vehicles that ive driven
Old Jul 4, 2009 | 06:50 PM
KVRunner's Avatar
I cranked the torsion bars on a dodge dakota I used to have after I got new torsion bar keys. The truck felt no different at first, but after a couple of weeks of driving it I felt that it rendered the truck almost undriveable.
Old Jul 5, 2009 | 05:33 AM
Teuf's Avatar
if you crank m, lower your tire pressure a bit (33' tires, 36 lbs )
Old Sep 11, 2009 | 08:13 AM
bikerbob's Avatar
Is there a stock spec for the rear fender - rim?
Old Sep 11, 2009 | 10:06 AM
94sasyota's Avatar
Be prepared for it to ride like a lumberwagon (KVRunner)
hahahaha
Old Sep 12, 2009 | 09:38 PM
Jay351's Avatar
p.s 33x10.50" tires fit STOCK with no lift!!!
voiddweller
19
May 2, 2016 09:10 PM
noahstancik
Jul 10, 2015 11:18 AM
zytra
Jun 24, 2015 08:14 AM
saphirekosmos
Jun 22, 2015 10:26 AM
Mr.Black
Jun 21, 2015 10:17 AM
