Hooked my battery up backwards
So i replaced the battery in my 1995 4runner it seems i was distracted and hooked it up backwards. Needless to say I replaced the 80 amp fusible link and a couple 15a fuses still wont start cranks but wont start. Pulled ecu codes steady blink which says ecu is ok. Any ideas where to go next.
You can try to jump start a vehicle off backwards and you will not make it smoke or spark just ask one of our sales persons. We had to replace over $10,000 worth of control modules and it blew almost every light bulb in the car.
As far as you go check and see What else isn't working, lights, horns, wipers etc. A lot of times something small will cause a bigger problem. Hope its just something simple.
There is a chance you may have fried something in your ingnition system. I'm not sure what the 95 four runners use for ignition (cap and rotor style dist. or something more sophisticated). Definately check for spark...
RyanJ989
11
Apr 7, 2021 09:41 AM
tazman1972
11
Sep 28, 2015 10:32 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
Sep 24, 2015 03:30 PM
SCZIG
Sep 20, 2015 09:00 AM
