Sponsored by: CARiD
Hooked my battery up backwards
Old Jun 27, 2010 | 07:30 AM
denverdan's Avatar
So i replaced the battery in my 1995 4runner it seems i was distracted and hooked it up backwards. Needless to say I replaced the 80 amp fusible link and a couple 15a fuses still wont start cranks but wont start. Pulled ecu codes steady blink which says ecu is ok. Any ideas where to go next.
Old Jun 27, 2010 | 07:54 AM
hilandfrog's Avatar
Did you check your relays?
Is the slow burn wire on the + side at full capacity, not even sure this would matter if'N its cranking.
Repo
denverdan's Avatar
i replaced the efi relay
Old Jun 27, 2010 | 08:03 AM
denverdan's Avatar
Repo
Well to be honest I dont know what a slow burn wire is. As demonstrated by my battery mistake I'm not much of a mechanic.
Old Jun 27, 2010 | 08:31 AM
denverdan's Avatar
Yup it never smoked or sparked at all.
Old Jun 27, 2010 | 08:51 AM
hdwilson33's Avatar
You can try to jump start a vehicle off backwards and you will not make it smoke or spark just ask one of our sales persons. We had to replace over $10,000 worth of control modules and it blew almost every light bulb in the car.
As far as you go check and see What else isn't working, lights, horns, wipers etc. A lot of times something small will cause a bigger problem. Hope its just something simple.
Old Jun 27, 2010 | 08:52 AM
hdwilson33's Avatar
Old Jun 27, 2010 | 08:59 AM
denverdan's Avatar
Thanx for the suggestion. I just went out and checked everything radio, lights, horn, literally everything it all works. Is it possible the ecu code i got was wrong and the ecu is fried. Makin me crazy.
Old Jun 27, 2010 | 09:27 AM
wentz912's Avatar
So everything electrical works? Have you checked for spark at the plugs yet?
Old Jun 27, 2010 | 09:29 AM
denverdan's Avatar
yeah everything electrical works. No I havent checked for spark yet. I will tho.
Old Jun 28, 2010 | 08:43 AM
americanmcss's Avatar
There is a chance you may have fried something in your ingnition system. I'm not sure what the 95 four runners use for ignition (cap and rotor style dist. or something more sophisticated). Definately check for spark...
Old Dec 19, 2012 | 10:53 PM
Burch's Avatar
Well?
Well? What ended up being the problem?
RyanJ989
11
Apr 7, 2021 09:41 AM
tazman1972
11
Sep 28, 2015 10:32 PM
toyotasaurus
Sep 24, 2015 03:30 PM
SCZIG
Sep 20, 2015 09:00 AM
VT2LAB
Sep 10, 2015 09:36 AM
