Help ID a rubber o-ring found resting on lower suspension arm.
Old 05-15-2012, 07:20 AM
derockus's Avatar
1989 22RE 4Runner.
I was looking at the passenger side wheel (just doing some investigating before CV replacement) and saw this o-ring (or seal?) just resting on the lower suspension arm. Must've broken off something but WHAT?? A little puzzle for you guys. It is clean on the inside and just some surface dirt on the outside. It is not greasy at all (just some hints). I have no idea where it is from...
Attached Thumbnails Help ID a rubber o-ring found resting on lower suspension arm.-imag0230.jpg   Help ID a rubber o-ring found resting on lower suspension arm.-imag0231.jpg   Help ID a rubber o-ring found resting on lower suspension arm.-imag0232.jpg
Old 05-15-2012, 07:27 AM
waskillywabbit's Avatar
Looks the the end rubber off a CV boot.
:wabbit2:
Old 05-15-2012, 07:34 AM
derockus's Avatar
I thought so too but I took a look and while the boots are torn it didn't look like this particular piece came off of the boot. It also doesn't look like it ripped off the end of the boot, looks more like its own solid piece. That, and the lack of any grease makes me think otherwise but you are probably right.
I will look again tonight and try to find a match up somewhere. Thanks for your reply.
icentropy
09-16-2020 02:47 PM
shisha1999
07-13-2015 11:09 PM
HaydenConQueso
07-12-2015 05:22 PM
icentropy
07-09-2015 02:12 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Help ID a rubber o-ring found resting on lower suspension arm.
