Headlight bulb retaining clip
Took my 2010 Toyota Highlander to the shop today to see about getting a new clip to hold the headlight bulb in. The only option they had was to replace the whole headlight assembly. Is there somewhere I can purchase this online or does anyone have a broken headlight assembly they could take this part off of to purchase?
The part I'm looking for looks like this:
http://imgur.com/3Abtyka
You can start by calling pick-n-pull places and see if they have any Highlanders in the yards and see if you could pull the clip or whole assembly for cheap. But with such a new vehicle there may be few around or not. Or take the other clip out and compare to other Toyotas headlight bulb clips.
I did a search and found this. You can possibly find them cheaper. Do a search and you may find them cheaper if buying an aftermarket lens assembly is your last option.
Here is a link I found for your ride. Don't know if it's legit or not. There may be a link on the site also to a manual.
Good luck and do some research online...
hiluxinargentina
Sep 30, 2015 05:51 PM
