Sponsored by: CARiD
hard brake pedal no stopping power please help?
Old Nov 20, 2012 | 03:25 PM
69must's Avatar
Sorry if this has already been answered but could not seem to find it when searched i got a 93 yota dlx v6 4x4 i have replaced multiple lines new master cylinder wheel cylinders caliper rotors drums shoes almost everything. i got a hard pedal but no stopping power i have vaccum to the booster everything bleeds fine just cant seem to get good brakes any help would be great thanks
Old Nov 20, 2012 | 04:42 PM
ksti's Avatar
Unless there is a line blockage (unlikely) you should have vacuum at the booster, that doesn't necessarily mean its working properly.
Old Nov 20, 2012 | 05:43 PM
Chickenman's Avatar
That was my thought exactly
Old Nov 20, 2012 | 05:58 PM
rworegon's Avatar
Are the rear brakes properly adjusted? The threads on the adjuster screw clean and greased?
Old Nov 20, 2012 | 06:06 PM
brianh699's Avatar
You say you have vacuum at the booster, I assume this means engine vacuum. Have you checked your vacuum booster for a leak? Hand vacuum pump is all you need to test.
Old Nov 21, 2012 | 11:07 AM
69must's Avatar
ok is there a certain way to test it? yes the backs are adjusted and i did grease the self adjuster how do i do that vaccum test i did the pump break start and it goes down i pulled the hose of and hear the booster relieve air any other test would be great?
Old Nov 21, 2012 | 11:09 AM
69must's Avatar
if it is the booster is there another type of booster i can put on? i would hate to spend the money on a new one a substitue would be great?
Old Nov 21, 2012 | 11:18 AM
brianh699's Avatar
The booster should hold vacuum when applied, vacuum shouldn't drop unless brakes are applied.
Old Nov 21, 2012 | 11:30 AM
69must's Avatar
o so when i pull the hose the air shouldnt come out?
Old Nov 28, 2012 | 12:32 PM
BumbleYota's Avatar
Are you sure the lines are completely bled? You can buy a one man bleeder that also has a vacuum tester. I payed around $50 I believe at oreiley auto. I assume you have new fluid? If the fluid is dark or rusty brown looking it can compress without actuating the piston/cylinder. Also is the pedal stiff in a normal way or in a binding way? Also make sure you have no lube on the pads.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
skoti89
Jul 8, 2015 12:05 AM
