Sponsored by: CARiD
Gears gears and more gears with 33's
Old Jun 29, 2011 | 09:00 PM
live4soccer7's Avatar
Ok... So I finally was able to find a good deal on some 33x12.5 tires!! Oh ya. Haven't put them on yet for a couple reasons. One, I don't have the time to mess around with them to get them to fit yet b/c I need to drive it and I figured I may as well regear at the same time or close to it.
I'm not to familiar with the gearing in the trucks, so if anyone has seen good threads/articles on it I'll read away. I did a quick search and found bits and pieces and it seems the stocks may be 4.10 and a suggested for 33's would be 4.88's.
The rig will be a dd, but won't travel long distances too often as I don't have to drive far for much. Although, it would be nice to have it geared for economy, but I'll make that decision when I know more about it.
Old Jun 29, 2011 | 09:08 PM
justin_4runner's Avatar
to see what gears u have u can look on the inside of the door and it gives u a code and u can see what gears u have, yes for 33s best would be 4.88s but also 4.56 are not bad idea too. if u plan on going any bigger go with the 4.88s if u dont then 4.56 wouldnt be too bad too. i have 4.56s in my 4runner and will be getting some 33s on it soon. right now im running 31s and at 70mph im at about 3gs and lots of power. but thats just my thoughts.
Old Jun 29, 2011 | 09:13 PM
jlshaff9's Avatar
hated my stock 4.10, happy since going 4.88
Old Jun 29, 2011 | 09:17 PM
dropzone's Avatar
Fossilized
gears have been covered quite extensively...
4.88's for 33's
Old Jun 29, 2011 | 10:34 PM
How much of a difference, at highway speeds, would I be looking at with 5.29's from 4.88's in case I want to get 35's in the future?
Old Jun 29, 2011 | 10:55 PM
Holywhitebread's Avatar
also curious to know this answer.
Old Jun 30, 2011 | 02:51 AM
dropzone's Avatar
Fossilized
here is a good gear calculator to play with:
http://www.grimmjeeper.com/gears.html
allows you to input tire sizes, gear ratios etc
Old Jun 30, 2011 | 04:27 AM
waskillywabbit's Avatar
IFS but everything is there
https://www.yotatech.com/forums/f116...osting-204178/
:wabbit2:
Old Jun 30, 2011 | 09:31 AM
Sweetness. Pretty sure that will do the job. I'll be readin for a while. Thanks.
Old Jun 30, 2011 | 09:34 AM
MaK92-4RnR's Avatar
3.0 v6 5 speed 33s with 4.88s here. I rev at about 3k at 65 mph.
Old Jul 3, 2011 | 03:05 PM
eric924run's Avatar
Im sorry i dont know if i should ask this here. I have a v6 8in with 4.56. want to purchace elocker rear end or just third member. could i reuse the pinon and ring on the elocker carrier.
Old Jul 4, 2011 | 06:21 AM
Many Toyotas's Avatar
Wink Gears gears and more gears with 33's
Pretty sure my 97 4runner has stock gears, 4cyl / 5 speed , turning 33's is awesome for the first 3 gears , 4th gear is useable most of the time, but 5th gear is down hill only, with a tail wind !!!
Old Jul 4, 2011 | 07:04 AM
84YotaBuck's Avatar
Been running 4:10's with 33's for a year now and it's really not that bad, although, my engine is in good shape with a EB cam and Weber carb for a little extra oomph. Don't do much highway driving, but when I do, 5th is flat or downhill only and I'd better be hittin 65+ before I shift into it!
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
