Sponsored by: CARiD
Gears
Old Jun 21, 2012 | 07:40 PM
Gasportsj7's Avatar
Gears
I just bought at 1987 pickup. Sits on 33's with a 3 inch suspension and 3 inch body. Its super slow and wont hardly get over 55 mph. would 4.88 be fine or do I need more?
Old Jun 21, 2012 | 08:58 PM
dropzone's Avatar
Fossilized
4.88's are recommended...if you plan on going beyond 33's do it once and get 5.29's
Old Jun 21, 2012 | 09:09 PM
Tofer's Avatar
Sponsor
depends on a couple of things
1) is it your daily driver or just a play toy? if you dont DD it, go 5.29s.. even if you do DD it, over geared wont kill you. i had 5.29s on 31s for a while on my DD'ed rig.
2) you you plan on going bigger tires? if you do, go 5.29s
3) are you going to SAS it? if not, you can find 4.88s that came stock in some rigs.
Old Jun 21, 2012 | 09:11 PM
drew303's Avatar
what kind of tire? should be able to do 65 on 33s no problem. 4.88 is the proper gear for that size tho.
Old Jun 22, 2012 | 07:11 AM
Gasportsj7's Avatar
I appreciate it. Will either gear make a difference on my gas mileage? because it is going to be my daily driver.
Old Jun 22, 2012 | 08:36 AM
4Crawler's Avatar
On my '85, I got better MPG w/ 5.29s and 33s than w/ 4.88s, but the speedometer is more accurate w/ 4.88s. Also I found 4.88s are more comfortable driving on longer road trips than the 5.29s. Winding out at 3300-3500 RPM for hour after hour gets tiring with the added noise and vibration.
Old Jun 22, 2012 | 08:48 AM
Philbert's Avatar
Do you guys know what trucks came standard with 4.88s?
How do you check at a boneyard if a third is in good shape?
Old Jun 22, 2012 | 08:59 AM
Gasportsj7's Avatar
what was the difference in gas mileage between the 5.29s and 4.88s?
Old Jun 22, 2012 | 04:13 PM
ZUK's Avatar
ZUK
The difference may or may not be worth mentioning. It just depends on too many factors.
Is yours a 5 speed or auto?
Old Jun 22, 2012 | 07:19 PM
Gasportsj7's Avatar
I got ya. its a 5 speed
Old Jun 22, 2012 | 07:50 PM
Teuf's Avatar
With 33's and a 3 in suspension get rid of the BL. If you stay with 33's do the 4.88.
Old Jun 22, 2012 | 08:03 PM
Gasportsj7's Avatar
Yea i was thinkin about gettin rid of the body lift we 33's I think it'd look better. what yall think?
Old Jun 23, 2012 | 09:05 AM
rbmoomba's Avatar
I run 4.88 v6 diffs with 35's. No problems. I pull a kayak and aluminum boat frequently. 3000 rpm at highway speeds 70-75.
mskalmus
May 28, 2017 07:51 AM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
