Sponsored by: CARiD
Gasket or Slicone
Old Mar 8, 2007 | 08:14 PM
KillChain's Avatar
Gasket or Slicone
I'm doing a thermostat change in reference of tips and tricks.
http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Do I need any other gasket or silcone material when I replace the thermostat? On a 22re 1990 4x4 PU. The extra material is for around the inlet housing or I just need the o-ring gasket only.
Thanks for any info.............
Mark
Old Mar 8, 2007 | 08:31 PM
Elton's Avatar
bead of slicon will be fine just let it cure for a little while first
Old Mar 8, 2007 | 11:07 PM
deserttoy84's Avatar
if its not sealing with a new thermostat gasket then use some silicone. I recomend getting a tube of toyota-bond or oilpan/camshaft cover silicone directly from toyota. is a little pricey for a tube of it but it works awsome.
Old Mar 9, 2007 | 07:22 AM
4Crawler's Avatar
I just use the o-ring around the t-stat. I gets clamped between the two halves of the housing and usually seals up just fine.
_Nicco_
Sep 21, 2015 03:06 PM
Obmi
Sep 16, 2015 02:13 PM
bootscootboogie
Sep 5, 2015 05:57 AM
Scotto6591
Sep 3, 2015 07:38 PM
scottyg486
Jul 19, 2015 05:34 PM
