Sponsored by: CARiD
G027 code 3.9 gear ratio
Old Feb 26, 2011 | 05:09 PM
octc's Avatar
I'm a newbie here. just purchased a 92 4runner 2WD. Vehicle came with 31x10.5 and from the axle code it looks like the truck has a 3.9 gear ratio. Can anyone let me know if this needs to be adjusted if we keep the 31s?
Old Feb 26, 2011 | 05:26 PM
MudHippy's Avatar
That makes no sense. G027 isn't possible. The last digit, 7, can't be right. There is no 7, only 2/3/4/5/A/B/C. G stands for an 8" differential, and 02 would be 3.36. The 31" tire option came with 4.556. So 4.56(G252 or G254)would be stock.
See this link: http://toyota.off-road.com/trucks-4x...ion-18588.html
Old Feb 26, 2011 | 08:42 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
a 2WD, with factory 31's?
Old Feb 27, 2011 | 03:26 AM
peow130's Avatar
Its a 2wd 4runner.. so it can have 2wd.
And it probably is 3.90, hell I've got 2 of those 8 inch 3.90 diffs outside lol.
Old Feb 27, 2011 | 06:13 AM
octc's Avatar
Go27 code 3.9 gear ratio
G027 is correct. it is on the door tag. i don't know if they were factory 31's. I believe the 92s came with two options 225s or 31s. The 31s are retreads so we are getting 4 new tires. I researched the code-gear ratio and the 3.9 is what came up but i know that may not be accurate so we may have to do the manual test. My big question is that if we stick with 31s should we change the gear ratio to a 4.3 if it is 3.9?
Old Feb 27, 2011 | 08:31 PM
MudHippy's Avatar
Exactly. It's a 1/2 ton 4WD chassis, with an 8" rear end and suspension setup to handle them, so why wouldn't it come with 31's? It just don't have a front axle and a transfer case.
That axle code's wrong though too. I don't care who says what about that. It probably does have 3.90's, I agree. But the code would have to be G074 or G072, NOT G027. NO CODES END IN 7, ONLY 2 3 4 5 A B C.
The chart below also states:
07=3.900
4x2 4R V6 AT
also '81 4x4's
92 2WD 4Runners with V6's also came with 3.417's. All V6's have 8" rear axles, most have axle codes that end in 4 or B(4-pinion, open diff), some end in 2 or A(2-pinion, open diff). Likely codes for those then would be: G384 or G382(8" 3.417), B01B or B01A(8" 3.42)
41201
FINAL GEAR KIT, DIFFERENTIAL, REAR
1988.08-1995.01 VZN85, 90.. HLF.. (CBU, IV3)1
41201-29546 41201-29547(MAIN)
41204-3508 (SUB)
41214-26011(SUB)
Replaced by: 41201-29547*
Manufacture notes: *FGR=41:12=3.417
http://www.toyotapartszone.com/Page_...onentsIndex=27
smthwsn357
May 1, 2024 07:28 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
mengquis
Jul 13, 2015 10:39 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
