Sponsored by: CARiD
front end shakes bad!!!!!
Old Feb 10, 2010 | 07:13 AM
wil824's Avatar
i have change everything i can think of, rotors,pittman arm,tie rods and bearings. it only does it when i push on the brake pedal and the harder i push the worse i gets. all parts are new from NAPA. help!!!!!!!
Old Feb 10, 2010 | 07:21 AM
waskillywabbit's Avatar
Only when you brake? Why do all that other stuff?
Old Feb 10, 2010 | 07:33 AM
wil824's Avatar
because i was trying to weight out all possibilties and somethings need to be replaced anyway because the truck has 232,000 miles on it. can you help??????
Old Feb 10, 2010 | 07:41 AM
BigBluePile's Avatar
Your tires aligned, wheels balanced? Auto, manual?
Old Feb 10, 2010 | 08:48 AM
wil824's Avatar
its a automatic and i had front end align and the wheels check for balanced. all is good. i have goodyear tires A/T on the truck.
Old Feb 10, 2010 | 09:20 AM
Did you bleed the brakes?
Old Feb 10, 2010 | 09:29 AM
91_TOYOTA_4x4's Avatar
do you have warped brake disc's? my buddys van has warped dics and it gets woboly a bit when on the brakes.
Old Feb 10, 2010 | 09:57 AM
wil824's Avatar
no i have not bleed the brakes yet. i will do that tonite. i will let you know what the outcome is. thanks
Old Feb 10, 2010 | 11:21 AM
quasi's Avatar
if the front end shake is felt through the steering wheel, suspect the tires, if through the brake pedal, suspect the discs
Old Feb 10, 2010 | 11:50 AM
wil824's Avatar
i have rotated the tires too and it still shakes. i fell it and the steer wheel and the whole front end of the trucks.
Old Feb 10, 2010 | 12:30 PM
brian2sun's Avatar
I would take a look at your pads and calipers too, maybe a piston jammed up or something.
Old Feb 10, 2010 | 12:33 PM
Justinvd's Avatar
What year and model toyota is it?
Old Feb 10, 2010 | 12:49 PM
wil824's Avatar
1992 toyota 4x4 pickup 22re motor automatic.
Old Feb 11, 2010 | 12:32 PM
wil824's Avatar
i bleed the brakes and its still doing it.
Old Feb 13, 2010 | 06:18 AM
eddieleephd's Avatar
could be power boost fluctuating... or
"brian2sun I would take a look at your pads and calipers too, maybe a piston jammed up or something."
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
Daneums
Aug 20, 2015 05:36 AM
toyoda8488
Jul 5, 2015 10:18 PM
