Sponsored by: CARiD
first 22re rebuild
Old Sep 15, 2009 | 09:40 PM
01tacoext
Guest
Posts: n/a
first 22re rebuild
so ive been scraping off the old head gasket, anything i should watch out for? i have been gently scraping it off and vacuuming the debris, but some... not a whole lot but SOME debris fall into the coolant passages, is this a big no no? or is SOME ok?
furthermore, im taking the head in to get looked at, what should i ask the machinist? i was planning on tellin him to resurface for sure, check for warpage(cuz im an idiot and didnt take off head bolts in order) & retap or helicoil the spark plug holes, got 80k on the head so i doubt it needs a valve job...should i get it anyways? would everything i want be more worthwhile to get the whole valve job?
okay ill take a break with the questions for now...later im gonna need help lining up the chain correctly, it doesnt seem as easy as tdc cyl #1 cuz it easily moves over a tooth or so with a slight turn of the crank, so id hate to tear it all back apart...
MUCH APPRECIATED THANKS
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coleypull15
Nov 3, 2015 07:41 AM
shisha1999
Sep 21, 2015 08:22 PM
shadowbirdie
Jul 21, 2015 10:38 PM
