Sponsored by: CARiD
Engine/Exhaust ticking mystery??
Old Apr 26, 2012 | 07:37 PM
xxxtreme22r's Avatar
Nope. The cam lobe overlap affects dynamic compression. The pistons affect static compression.
It's hard to explain, but the shorter the overlap, the less air gets into the engine on one revolution hense lower compression and lower vacuum. The longer the overlap the more air that gets into the engine on a single stroke hense higher compression and larger vacuum.
For example if you have a cam that causes a loping idle it's due to the fact it causes a lower vacuum at idle. Alot of these types of cams require some sort of modification in a power brake system because of it.
What I can't remember off hand is if that dynamic compression can be seen in a compression gauge or not or if you have to turn the engine a few more times then normal when dealing with a cam like that to get a more accurate compression reading.
I don't think that 272 cam is one of those cams though. Which one is it? The Engine Builder branded or a Comp Cam?
Old Apr 26, 2012 | 07:43 PM
JPL's Avatar
JPL
Not sure on the cam but I plan on turning over the engine more than a few seconds on each cylinder next time. Also, the engine seems to idle smooth and has most its power between 3-4.5K RPM.
Still like to troubleshoot that "exhaust leak noise".
nvwiggins
13
Jun 16, 2016 03:05 PM
Davebarbier
Nov 3, 2015 03:28 PM
kawazx636
Sep 29, 2015 08:22 AM
Tacoma1313
Sep 15, 2015 07:51 AM
ErikZ1220
Sep 10, 2015 04:53 AM
